What Is the Best Porcelain Tile Thinset Mortar?
Michigan Ray
Michigan
Hi, I'm going to be installing a kitchen countertop along with a full backsplash (between upper and lower cabinets on new primed drywall). I will be using 6" x 6" porcelain tile. I would like some suggestions for thinset mortar that has high tackiness for the walls as well as the countertop. I will be using either Hardiebacker or Durock on the countertop Thanks in advance for the help, Ray
Check out this thread http://www.johnbridge.com/vbulletin/showthread.php?t=34610 .
Especially if you decide to use HardieBacker...make sure to take a wet sponge and liberally wash it down before spreading your thinset. That stuff is VERY thirsty, and will suck too much moisture out of the thinset. As long as there's no surface water, you can't make it too wet, and it gets any dust off before you try to start setting your tiles.
Eurob
master tile and stone installer
Montreal
www.houzz.com
Quite few best mortars out there for your application , Ray .
Ardex X77
Kerabond T & Keralastic
To name some .
Do not forget to complete it with an epoxy grout which can also give you best results .:)
