What is a six-unit trap?
Discussion in 'UPC Plumbing Code Questions' started by seattle_steve, Jan 13, 2011.
  1. seattle_steve
    seattle_steve New Member
    Jan 13, 2011
    Seattle, WA
    I'm remodeling and adding a second floor bathroom. King County (Seattle) plumbing code says that a 3" stack can accommodate 48 DFUs, which is more than enough for me. However, there is a footnote that states:
    "Only four water closets or six-unit traps allowed on any vertical pipe or stack..."
    I only have 2 toilets connected to the stack. But I'm confused by "six-unit traps". At first I was reading this as limiting you to "six trap arms" connected to the stack (which would be more than I have planned to connect to the stack -- if you count the toilets). But, now I'm thinking that a "six-unit trap" is something else altogether (like a 4" trap?) and hopefully I don't have to worry about it. Google wasn't much help so I thought I'd ask here.
    Anyone?
    Here's the reference (see footnote "d"):
    http://www.kingcounty.gov/healthservices/health/ehs/plumbing/unitvalues.aspx
    Thanks.
  2. Terry
    Aug 17, 2004
    A six-unit trap is a 3" trap.
    Your shower uses a 2" 4-unit trap.
    Size of Trap and Trap Arm, Drainage Fixture Unit Values (DFU)
    702.1 for Maximum sizing.
    1-1/4" 1 unit
    1-1/2" 3 units
    2" 4 units
    3" 6 units
    4" 8 units
    From Table 7-3 of the 2009 UPC
  4. seattle_steve
    Jan 13, 2011
    Seattle, WA
    Thanks for the response, Terry. But I'm still a bit confused, because the first table on the King County page I referenced lists a toilet as 3 units and a shower as 2. What am I missing?
    Is there a difference between "fixture units" (which the King County page is defining) and "trap units"? If so, I appreciate the values you provided, but does King County have that documented somewhere? Or is it just in the UPC?
    Thanks.
  5. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    I don't know why you're making this so confusing for yourself.
    There is no unit-trap, no six-trap, no whatever else. Only fixture units.
  6. Terry
    Aug 17, 2004
    The chart comes from the 2009 UPC Code book that Washington State uses.
    I don't know if Canada uses code books, but since the homeowner is Seattle_Steve and has listed the King County web site for information, this will be good information.
    You don't have any 3" p-traps in your home, so I wouldn't worry about it. You normally only see a 3" trap in a commercial situation.
    These are max limits for the trap sizes.
  7. seattle_steve
    Jan 13, 2011
    Seattle, WA
    Ok, thanks Terry. That's good enough for me. (Yes, I'm in Seattle.) Thanks.
  8. hj
    in the "old days" toilets WERE a 6 unit fixture, but with the low GPF, it has been reduced.
  9. seattle_steve
    Jan 13, 2011
    Seattle, WA
    Ah, now I get it. That totally makes sense hj. Thanks!
  10. jimbo
    jimbo Plumber
    San Diego, CA
    What they are saying is that toilets and showers are "excpetions" to the general rule. They are a larger trap, but with typical volume much less than an application using a 2", or 3", trap in a "regular" way. Just for example, a washing machine places a much bigger load on a 2" trap than does a shower. A shower, nominally, delivers 2.5 gallons per minute. A washing machine can potentiall deliver 10 times that amount
Similar Threads: six-unit trap
UPC Plumbing Code Questions Is this too much direction change for trap arm? Mar 13, 2017
UPC Plumbing Code Questions Standpipe/p trap in crawlspace Feb 9, 2017
UPC Plumbing Code Questions P-trap install. Stubs out too low. Jan 23, 2017
UPC Plumbing Code Questions Distance from tub outlet to P-trap Apr 21, 2016
UPC Plumbing Code Questions TRAP ARMS Sep 16, 2014
