What in the world is this?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Rocker, Apr 28, 2009.
  1. Rocker
    Rocker New Member
    Apr 28, 2009
    HVAC Guy
    Texas
    Boy, am I glad I found y'all!
    I bought a 30 yr old house with a water well. It has a motor driven air pump that blows air down the well. Water comes up and empties into an above ground concrete tank, about 1000 gallons. There's a typical well pump mounted on a pedistal next to it with its intake plumbed down into the cistern and its output into a typical big blue tank that runs into the house. I can't find any filtering device, save for one under the kitchen sink. I'm about 75 miles north of the gulf coast, 225 ft in elevation, and far enough from Houston that the air's not chunky. I've never seen anything like this setup before, but I'm a city boy and therefore, a throughly dangerous man (a little bit of knowledge...) What's the best approach to a proper filtering system? Is this a safe/practical setup? The pump is less than a year old. The cistern is not sealed airtight. What do I need to do for control of bacteria? I'm an HVAC guy in new home construction so I know which way to turn a wrench, but I'm way outta my element here and defer to more educated folks for direction. Any help is greatly appreciated.
  2. Gary Slusser
    Retired
    First you need a water tests for hardness, iron, pH and Coliform bacteria would be good. The sample should be taken as close to the well (the tank inlet) as possible but not out of the tank. Then a sample from the house and test for hardness and iron. Then post the results. Labs are found under the heading Water Analysis in the yellow pages, or ask your county extension office, or take a sample to Sears or use dip strip test kits you can buy at any hardware and most big box stores. Coliform bacteria will probably have to be done by a lab or the county extension office.
Similar Threads: world
Pumps and Tanks Well Forum & Blog. Water is life. CSV Question - Best of Both Worlds Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Real world vs rule of thumb - How do you figure GPM & what happens if pump cannot meet demand? Oct 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Newbie to the World of Wells and Pumps with ??? Nov 21, 2007
