What fitting do I need?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mihomeowner, Apr 2, 2014.
  1. mihomeowner
    mihomeowner Member
    May 27, 2013
    Michigan
    I am installing a humidifier. It comes with a saddle valve to attach the 1/4 inch OD tubing for the supply. I don't want to use a saddle valve, haven't heard good things. What fitting do I need to install in my 1" copper line to be able to tap off the line and attach the 1/4" compression tubing?
    Thanks
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    You need a 1 X 1 X 1/2 CCC tee and a 1/2 X 1/4 angle stop.
  4. mihomeowner
    mihomeowner Member
    May 27, 2013
    Michigan
  5. hj
    uote; Thanks, that's helpful. Ever used these fittings
    Of course. Every time we need them, but you also need a way to get that tee inserted into the pipe, unless it is flexible enough to separate for the insertion.
Similar Threads: fitting need
Plumbing Forum, Professional & DIY Advice Backflow fitting needed? Is different metals acceptable? Aug 8, 2014
Plumbing Forum, Professional & DIY Advice How tight do you need to tighten a compression fitting? Mar 3, 2013
Plumbing Forum, Professional & DIY Advice Need help/ideas on how to remove a plastic pipe fitting Jan 23, 2013
Plumbing Forum, Professional & DIY Advice Proper fitting needed, toilet sits ontop of stack, short distance to septic Dec 17, 2011
Plumbing Forum, Professional & DIY Advice New Sink. Need a double check on DWV fittings Jul 14, 2010
