What effects would pressure treated wood have on copper plumbing pipes - they touch!
Discussion in 'Shower & Bathtub Forum & Blog' started by johnfrwhipple, Feb 12, 2011.
  1. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    I was quoting a new job today and noticed that the framer (Home Owner) used two pressure treated 2"x4" to frame around the shower fixtures. The plumber (Home Owner) also drill nice tight holes and the copper pipping is touch the pressure treated studs.
    I understand that there is special fastners and gaskets needed to keep materials not designed to work with pressure treated lumber from making contact.
    I have suggested replacing the studs and the Client does not wish to do this.
    I have further suggested I use my Fein Multimaster and remove enough of the studs around the pipe to prevent the copper lines from touching. I suggest then using some "Mickey Mouse Ears" and pressure treated screws to secure the pipes.
    The client does not think this is necessary and my gut tells me it is mandatory.
    "WHAT SAY YE PLUMBERS?"
    Anyone have first hand expierence of the chemical in the pressure treated wood causing a pipe failure?
    Any insight would be most welcome.
    Thanks.
    JW
  2. Terry
    Aug 17, 2004
    As you know, most plumbers drill 1-3/8" holes, then you can use plastic inserts, or the winged pipe holders.
    I don't know about the treated lumber against copper, maybe someone else does.
  4. jadnashua
    It really depends on which type of treatment was used in the wood. One type is copper based, and shouldn't affect the copper pipe at all if the fasteners are SS or G185 galvanized (or copper). But, if Borate based, then you may have problems. Not sure what type(s) are available where you live, or what was used. Most of the 'older' treatements could be an issue.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    We are not allowed to use treated lumber indoors... period.
  6. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Thanks Guys.
    I have not used pressure treated lumber personally before inside. I save it for decks and such. That said the client is the home owner. The client has done all this work and has no plans of ripping out all their hard work.
    I will break out the multimaster and open up some real estate around the copper lines. Some mickey mouse ears and a few pressure treated screws and we should be good to go.
    JW
  7. Terry
    Aug 17, 2004
    Many of the slab on grade homes I've worked on had pressure treated plates at the concrete floor.
Similar Threads: effects pressure
Shower & Bathtub Forum & Blog Shower Pressure Problem Jan 21, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Need help with Pressure Spool Jul 25, 2016
Shower & Bathtub Forum & Blog Occasional Low Water Pressure Jan 19, 2016
