What Causes Toilet Bowl Overflows
Discussion in 'Toilet Forum discussions' started by student, Nov 8, 2006.
  1. student
    student New Member
    Nov 8, 2006
    I am doing a report on toilet overflows. I know if something gets stuck in the toilet bowl, the toilet will overflow. Can anyone explain the dynamics/mechanics/hydrologic of why this happens. I need a simple explanation that almost anyone can understand. The concept is not real clear to me and I have searched every where on the Internet to find the answer--with no success.
    Your help would be greatly appreciated.
    Thanks!!!
  2. Terry
    Aug 17, 2004
    Take a one gallon pitcher of water and a 12 oz glass.
    Start pouring until the pitcher is empty.
    That's what an overflow is.
  4. student
    student New Member
    Nov 8, 2006
    What Causes Toilet Overflows
    Terry. Thanks. Your description is super. So, the outlet from the bowl to the sewer gets blocked (clogged) and water can't escape from the bowl, right? Then when water enters the bowl from the tank on a flush, your gallon to 12 oz glass scenario comes into play.
    But, in my experience, whenever I experience an near overflow or overflow, the only way to prevent it or stop the water flowing is to lift up the lid from the tank and pull up on the float ball. This shuts off the water and stops the overflow. Why does this work when on the flush all of the water from the tank has already emptied into the toilet bowl? Is the new water coming into the tank enough to tip the overflow scale, so to speak,. If so, how does that water get into the bowl if the flush valve (flapper) is closed?
    I've prevented many overflows using this method but don't understand how and why it works.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    There is a standing overflow pipe inside the tank and a refill tube is extended to it from the fill valve. Until you lift the float ball or float assembly, water flows into the toilet bowl........
  6. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Here is a picture of the tube that plumber1 is talking about. It continues to send water into the bowl via the overflow even when the flapper is closed (As long as the toilet is refilling).
  7. hj
    overflow
    With the older high gpf toilets, there was more water in the tank than the toilet could hold when it was plugged. With those you had to push the tank ball, or flapper, closed before it overflowed, AND stop the refill tube from adding more water into the bowl.
Similar Threads: Causes Toilet
Toilet Forum discussions toilet flushing causes gurgling in adjacent bathtub drain.... Jun 11, 2014
Toilet Forum discussions What causes toilet spray? Nov 5, 2009
Toilet Forum discussions Toilet flush causes sink to gurgle Feb 10, 2008
Toilet Forum discussions Toilet Flushing causes pipe rumblings Apr 9, 2007
Toilet Forum discussions Kohler Rialto toilet causes drain clogs?? Jun 22, 2006
