What Brand Pressure Tanks are Recommended?
PumpMd
Kevin
Oklahoma
2nd: Wellmate quick disconnect tanks, the classic models were holding up but when they went to the quick disconnect, they started having problems. Pentair states they are not having problems (Right). I had to put air back into the air cell to find a very tiny pin hole, which you cant really see in the picture at the bottom part of the air cell.
PumpMd
Kevin
Oklahoma
Would the air cell be at a higher temperature? It is buried so I would think it would be cooler in the ground or do mean for the freezing temperatures.
PumpMd
Kevin
Oklahoma
Only cut the top ring off, leave the extra space so you can slide the valve cover box onto the 5gal bucket. That will give you 2ft.
PumpMd
Kevin
Oklahoma
I got a Wellmate air cell from their classic model WM-14wb, 21inch diameter & 41inch long, to fix the problem. It was either I found something that worked or I was going to dig back up the tank, since Pentair discontinued the PSC-35-10, 21inch diameter & 37inch long. I did go back with sand & didn't dig it myself because it was all sandstone.
PumpMd
Kevin
Oklahoma
I am thinking about February.
I believe you said that you use to have a pit? If so, did you ever put a heater in your in your pit. I find them all the time here without a heater & their old bladder still working.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Only the bottom of the tank has water. So if the top of the tank is 18" below ground, the bladder and water will be well below the freeze level. Unless it sits unused for a long time, the bladder will be the same temperature as the water. Bladders or diaphragms in tanks can handle a pretty wide range of temperature. The bending back and forth from the pump cycling is what will eventually get them.
PumpMd
Kevin
Oklahoma
Rub marks on the side & the hole on the bottom of the air cell again.
