What are the best undersink shutoff valves
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by usckww, Dec 6, 2007.
  1. usckww
    usckww New Member
    Dec 4, 2007
    I hate the shut-off valves typically installed, and want to have mine replaced. Are there any that are similar to a house main shut off? 1/4 turn, never leak? Suggestions?
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Yes, they now make 1/4 turn shutoffs for under the sink. That's all I use now.
  4. usckww
    usckww New Member
    Dec 4, 2007
    Can you recommend a brand, model # etc?
    thanks
  5. Verdeboy
    Jun 12, 2006
    I just get whatever they sell at the local hardware stores. Perhaps, the plumbing pros can give you a specific brand name.
  6. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    I've seen a lot of failures in the quarter-turn valves, and can not yet say with authority which are best. Although they're similar in construction to ball valves, I've seen them leak through the stems when turned and I've seen them leak when shut off. A week ago I was working with customer-supplied ball stops that wouldn't shut off, but were brand new.
    There are higher-quality ones made but they're seldom available because most suppliers stock based upon cost rather than quality.
    And there's no reason that you can't install quality ball valves with an adapter for faucets, except for cosmetic reasons.
  7. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    I prefer to use Dahl mini ball valves for just about every application. But I am not sure if you can get access to them. I know Brasscraft makes similar products and they are a pretty solid manufacturer.
  8. jadnashua
    My HD sells several brands, but Brasscraft is one of them. If you look in their catalog, they make a huge variety at various price points. Some are available in finishes other than chrome as well.
  9. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    I have used brasscraft 1/4 turn are good.
  10. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    I had some of the reqular old type valves back when they first switched to plastic stems that leaked out the handle. They just drilled a bit too deep into the stem for the handle screw, that has nothing to do with the quarter turn. It was even a good brand that I get from my supply house, just a bad run, was a pain to deal with, I had a box and more than half of them were like that. I bought valves at a chain store for a while after that. I love the quarter turns, brass craft are common and good.
  11. westcoastplumber
    westcoastplumber Plumbing Contractor
    Nov 30, 2007
    c-36 plumbing contractor
    los angeles
    I use 1/4 turn brasscraft angle stops, never have a leak, no packing to worry about, I have no problem giving a warrenty on them.
    I have never had one fail yet......:D
  12. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    LOL... I hope your keyboard's made out of wood!
  13. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    I've never seen a problem with a 1/4 turn angle stop, other than installation error. i've worked almost exclusivley in service the last 5 years and have never seen a problem except with the ferull/nut connection.
  14. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Vashon, Washington
    for those who have seen problems, I'd like to know what they found.
  15. Ian Gills
    Jul 24, 2007
    USA
    The only problems I have heard of are that they are difficult to sweat and prone to failure following that.
    Consequently I use compression or "screw on" where my two nipples allow me to do so. :)
  16. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    From the first time I saw 1/4 turn stops, I started seeing leaks through the stem and no way to tighten them. A week or so ago I had to disconnect some to work on a pedestal. They had been supplied by the HO and I don't know the brand. They would not shut off all the way.
    I'd be interested in trying the new Watts 1/4 turn with the sharkbite-type connection to the water line. Or maybe I'd just be compounding problems?
  17. construct30
    Jun 16, 2007
    NorthWest PA
    I've used sweat, compression and FIP quarter turns in watts and brass craft only ever had one leak around the stem packing. One thing I don't like is when they don't give you a full nut at the base for your wrench when you are in a tight location.
Similar Threads: best undersink
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Feb 20, 2017
Plumbing Forum, Professional & DIY Advice Best Way to Splice Water Off This Sink Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Best Methods for Revealing Pipe Issues Inside Walls? Dec 15, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Best way to connect a 2" and 1.5" to a 3" DWHR unit? Nov 11, 2016
