What actually does an uncoupling membrane do?
Discussion in 'Shower & Bathtub Forum & Blog' started by jadnashua, Apr 4, 2014.
  1. jadnashua
    What do you think holds the cable in place? It encircles EACH tower - it snaps into place because there's a back bevel. The most any single tower could have a cable in that slot is over 90-degrees when making a corner since you cannot just run it around the post...you cannot put the heating element closer than every third slot. That slot along with the shape of the whole mat, lock the thinset and tile in place. That you don't have an open mind and can see that for yourself and have to bash others says something about your character.
    The thinset is mechanically locked in place on Ditra Heat, which holds the tile in place.
    As to overheating...you do not want any significant air space around the heating elements or they can overheat...they must be (at least for the majority) covered in thinset. Try turning on your electric water heater without filling it up first...a very dramatic example of the need to be able to conduct the heat away...works fine when covered, burns up very quickly without. You need some mass there and the plastic mat doesn't have any by design.
    Ditra, and many other decoupling membranes have those raised ridges with air space underneath them and, consider, a heating element could easily be running straight along the top of one, at least somewhere in the installation. If you put the heating mat or elements on top of the mat, you'd have the heating elements crossing or following those air spaces...a great situation for a hot spot over each one. Ditra Heat is designed with minimal direct contact of the wire and the majority of it being encased in thinset and, those spots where it might touch the mat are relatively far apart compared to the structure of other uncoupling membranes, minimizing any heat buildup at that point. It's a matter of reliability. You MIGHT be able to make it work otherwise, but it wouldn't have the reliability of an engineered solution where they take into account the heat rise and the material properties. You can do that when you produce both the heating cable and the mat so you know how it works...that is a big unknown when you try to mix and match things from various suppliers. Another reason why these things are called systems, and not just components. And, Schluter is very conservative - if you install things like they say, you have as close to 100% probability it will work as designed as humanly possible.
  2. jadnashua
    FWIW, I never selected that picture...one day, it appeared. Since it didn't really matter to me, I never changed it. Terry tends to add one if the user doesn't pick one.
  3. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
  4. jadnashua
    If you can't see the lip on the tower, you're blind.
  5. Vegas_sparky
    Vegas_sparky Digital Billy
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    I'm sure this product went through extensive testing, but IF that mat was on a ceiling, would you stand under an 18"x18" piece of tile/stone set to it? Just out of speculation.
    I have to say, any mechanical bond to that profile looks like it'd be pretty weak. The lip has nothing to leverage against. The ridges on rebar aren't very big either, but they don't pull. Set a mat/tile on a temp board, hang it upside down, attach a suction cup and weights until it drops.
    Double or nothing a 12"x12" with any properly mixed/cured thinset will pass a garage test with a suction cup and 20lbs hanging straight down off it.
  6. jadnashua
    It IS specific as a FLOOR warming system. Using it elsewhere would not conform to the intended use. A good uncoupling membrane makes the tile/thinset layer much closer to a floating floor than any bonded system, minimizing any shear stresses, which is one reason why a good unmodified way exceeds the requirements to hold anything in place (an unmodified's minimum bond strength is 150psi, and a good one can double that putting it at over 5x the bond strength of the membrane), and that's what gives it the benefits...gravity does much of keeping things where you want, with the shape of the mat taking care of the rest, isolating it from the subfloor. The industry spec for this type of thing is a minimum of 50psi - it doesn't matter what the size of the tile is. I haven't seen test results for this mat, but feel very confident that it exceeds the industry standards.
  7. Vegas_sparky
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    How squishy is that mat? Is it as soft as say, Johns hands? He sure has pretty fingers. LOL
  8. jadnashua
    It's made out of the same plastic as the other Ditra uncoupling mats, if that helps. Once installed, and you've filled it up with the thinset and set the tiles, the actual flexibility of the mat is what provides the stress-relief in the lateral plane. The air space in the towers is what allows it to move horizontally without cracking the thinset or breaking a tile(not vertically)- IOW, it MUST be flexible to obtain the uncoupling. Keep in mind, you still have the rigid tile bonded to the thinset that keep the towers in place, only deflected as a whole assembly (tile/thinset). The areas where the thinset goes to the base of the mat are what provide the vertical support, and their spacing is the reason why there is a minimum tile size requirement - the tile needs to be supported by a minimum number of thinset towers to provide adequate compressive strength, only limited by the compressive strength of the mortar used. If you don't wear kneepads when working on your knees, you might want to use a kneeling pad, but you won't hurt the mat in the process - it will be more comfortable for you. That's pretty much true for any uncoupling mat.
    That is one reason why, as opposed to say a crack isolation membrane which needs to span a ways over a crack to have enough flexibility to actually isolate it, an uncoupling membrane does that from its inherent structure over the entire mat, regardless of its size - things can move any direction laterally, independent of the subfloor or slab and the width (contrary to what John thinks) has no impact on its decoupling capabilities.
    Any test trying to exceed the industry standards with any mat are misleading and mostly useless...all membranes of this type must meet a minimum of 50psi to pull it off the substrate (the fleece attachment layer will fail first), and that will be the weakest link in the system. The only way to determine how well it works for uncoupling would be to install multiple strain gauges in the sandwich, and measure how much stress can be applied before either a tile or a grout joint fails or breaks. No backyard test is going to do that, and with crude measurement tools, is mostly a joke and pointless. These things are designed for use on a floor, and you're not going to have something yanking the tile up (gravity doesn't work that way) or pull it sideways. Yes, the tile and the substrate move separately, but that's the whole reason for an uncoupling membrane, to isolate them. For any practical installation, it far exceeds anything needed. It does NOT reduce the need for expansion joints IN the tile - it only works between the substrate and the tile - the tile's expansion can exceed the strength of thinset regardless of whether it is attached via bonding directly or whether it is placed on an uncoupling membrane. The beauty of the uncoupling membrane is that thinset does NOT stick to it (at least on Ditra - why one would want fibers as part of the tile bond is beyond me, and probably mostly to avoid patent issues - they state that they tear in the process, anyways, so why have them!).
    The whole concept of you must use a modified thinset for attaching porcelain or glass IS true, IF you direct bond them in many cases. When using an uncoupling mat (and the installations from centuries ago used their version of an uncoupling mat - a packed sand bed - no cement, just sand and their glass and porcelain installs work just fine), you have probably at least a 300% stronger bond to the tile than any lateral stress that can be applied to it. IOW, it isn't going to come off unless you try to destroy it!
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  10. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  12. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  13. jadnashua
    FWIW, the rating categories of the Robinson floor test are: residential, light, moderate, heavy, and extra heavy. The description of the test result describes what they deem each level to be suitable for.
    Ditra heat, like any uncoupling membrane, will give different results based on the tile, the substrate, and some random factors based on the wood involved, and the fact that humans and nature aren't perfect, but look at test report TCNA-415-13, with OSB, 19.2"OC, and a 12x12" porcelain tile, it received an EXTRA HEAVY rating...the highest they give, (and better than the heavy you're so proud of) and also, Schluter pays for multiple tests, and only lists a rating that passes that level for EACH test sequence...some get one good rating, and use that, ignoring the others...nothing's exactly the same - Schluter wants it to work, when they say it will, regardless as long as you install it the way the say (something, you have a problem doing). They ran a bunch of tests using natural stone over Ditra with a single layer of plywood...the majority of the time, it passed the tests with a reasonable margin, but not 100%. As a result, they do not warrant natural stone over a single layer of ply...the result of being conservative and wanting to know the user can ALWAYS get it to work, backed up by testing, when installed as they say. They do not like 'ifs'...if it doesn't work, they either fix it during design, or don't sell it. That doesn't mean they don't make changes along the way based on feedback or technical advances or production methods, but the products have to continue to work as advertised WHEN INSTALLED ACCORDING TO THEIR INSTRUCTIONS (again, which John Whipple has a big problem with, thinking his way is better - sort of the NIH mindset some companies have (not invented here - if I didn't do it, it can't possibly be as good).
    Maybe a little research, rather than the knee-jerk, typical of you, reaction may be worth considering.
    For those of you who may have been following this since the beginning, John Whipple doesn't like me, dislikes anything I say, and tries to pick apart any bit of it. He now, also dislikes Schluter because they told he they were not pleased with his unscientific comparisons, incorrect installations, and various comments about their products...talk about vindictive. Schluter has been in business for decades, products sold around the world, has innovated many of the advances in materials and techniques for tile installations. That I admire them, is partly because I'm an engineer, retired, having worked in designing, testing, and teaching troops how to use various missile systems for over 30-years helps me to recognize and appreciate that innovation and professionalism Schluter has for their products and how they treat their customers. In my job, failure to do what we said could mean thousands of lives lost and billions of dollars in property damage - IOW, you have to get it right the first time. My experience is that Schluter has the same attitude, but like anything, you have to use it as it was designed. I have used products from other companies, and some are as good, some are lousy, and some have no overlap, so there is no choice. I have no agenda here, I do not get any commissions, or rebates, or financial incentives to post anywhere. John has an interest in making himself look good (and an obvious ego) and promote his business, and anyone that challenges something he says is an enemy...I think you get what I mean.
    Uncoupling mats work. You may not always need one. To me, if your choice was a cbu or an uncoupling mat, the uncoupling mat would always win, even if it cost more. For a pro, because of the speed and ease of installation, more than a few pros I know will only install cbu if the customer insists - the difference in cost of materials is easily covered in the time savings (labor is often a significant portion of the job)...the customer is always right, even when they're wrong. When the probability of failure isn't a big issue, yes, either will work, and one may be overkill (but John LIKES overkill, if you follow any of his methods). There are times when an uncoupling mat will be the only sane solution, but in many cases, you can get by without one.
Similar Threads: actually does
Shower & Bathtub Forum & Blog Help removing Delta cartridge, and is my water actually off? Feb 19, 2015
Shower & Bathtub Forum & Blog I think I screwed up my hopes for a Steam Shower... Actually, I know I did... Oct 11, 2013
Shower & Bathtub Forum & Blog Shower Handle Doesn't Turn + No Hot Water Dec 24, 2015
Shower & Bathtub Forum & Blog Does preslope need to go all the way to the drain? Sep 24, 2015
Shower & Bathtub Forum & Blog Does this tub drain look right to you? May 24, 2015
