WH heat trap interfering with Hot Water Lobster?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by eric28805, Aug 11, 2010.
  1. eric28805
    eric28805 New Member
    Jul 28, 2005
    Georgia
    I put in a Hot Water Lobster recirculating system and it doesn't seem to be working. After doing some research, it looks like my WH (5-year old Whirlpool Gold, 50-gallon) has heat traps that could be interfering.
    Is there an easy way around this? If not, is there a hard way around it?
  2. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    If it is a Whirlpool, the flame-lock system could be goofing things up. What do you mean by not working?
  4. eric28805
    Jul 28, 2005
    Georgia
    we just aren't getting the hot water any faster than before -- and the bathroom is almost directly above the water heater (two stories above)
  5. eric28805
    Jul 28, 2005
    Georgia
    is flame-lock a gas thing? I probably should have included that my WH is electric
  6. hj
    Unfasten the hot and cold supply lines, reach into the pipes on the heater and "yank" the heat traps out. BUT, there is more to a convection circulation system than just installing a "Lobster" in the piping. IF the pipes are not sloped properly to insure convective circulation it will NOT occur, without a pump, no matter what you do to the piping.
  7. 6t7gto
    6t7gto DIY Junior Member
    Jan 20, 2010
    Bedford, Ohio
  8. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    It seems awfully-expensive for what it is. The watts (grundfos) system with the pump and the end-of-line crossover valve and associated hoses is about $200. http://www.homedepot.com/h_d1/N-5yc...atts+recirculating&storeId=10051#.UQAxVSdtUj0 Ten dollars less in some other places. The replacement valve (or extra valve) alone is about $45. Google Grundfos 595926 "Comfort Valve". The Lobster is, if I understand, basically just the temperature-controlled valve. So its price seems high to me unless I am missing something. For that money, you might as well get the pump, too.
    I installed the Grundfos pump and two valves (one for each branch of our hot water system), and it works very, very well. It was 11 degrees out last night, and at the furthest reaches of the house, the tap water in the morning was warm within 2 seconds and hot not much longer thereafter. Before the pump and crossover valves, we would have to run it literally more than a minute on a morning like this before it was anything but ice cold. (Our plumber said, "Just seemed like a minute." Nope. More than a minute. I timed it repeatedly.)
    That said, there is NO WAY this thing "saves energy" as the literature would have you believe. The water has cooled more than enough by the time it gets back to the water heater that it isn't going to let you start with "warmer water". As a practical matter, it will come out a cold tap long before it makes it back to the heater, unless it's a very short run in which case the system won't add much. So much of the marketing material on that site is crap. However, with the pump the system does indeed get you hot water much faster than before.
  9. 6t7gto
    Jan 20, 2010
    Bedford, Ohio
    Thank you for the reply and the link.
    David
  10. DeLuke
    DeLuke New Member
    Jan 22, 2014
    Florida
    We have installed several Hot Water Lobster Instant Hot Water Valves in a variety of plumbing systems (water heaters in attics, basements and garages...pipes through crawls and concrete...reverse "pipe slopes") with great success. Since the water heater itself creates the pressure to circulate the water through the system, we found that the only thing needed is an open circuit between the HWL Valve and the hot water tank (no check valves or heat traps). Our customers rave about them.
    D. Luke
  11. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    the hot water heater creates pressure that's useful for circulation?? interesting.....
  12. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    This system uses the cold water feed, rather than a separate return line.
    It seems to me that either the return cold water into the heater should be at a bottom for a gravity system, or the dip tube should be somehow insulated.
Similar Threads: heat trap
Plumbing Forum, Professional & DIY Advice Do heat traps work Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Shower P-Trap Above Unheated Garage Mar 28, 2016
Plumbing Forum, Professional & DIY Advice Gas water heater-- sediment trap / drip leg length Feb 22, 2015
Plumbing Forum, Professional & DIY Advice Trap primer on hot water heater constantly flowing Jan 30, 2013
Plumbing Forum, Professional & DIY Advice Banging water pipes from water heater heat traps? Aug 5, 2010
