Wet venting shower through the lavatory - look okay?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mjsmith0, Feb 27, 2010.
  1. mjsmith0
    mjsmith0 New Member
    Dec 12, 2009
    Los Angeles, CA
    I think I figured out how wet venting works, but thought I should check with the pros first. Does the wet vented portion look proper? (The sink trap will be higher and the shower drain will be a little farther away.) I sketched in where the water closet drain connects to the drain stack just in case that makes a difference.
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    No, the Y should be inverted. The wet vent should come off the branch of the Y. And the weir of the shower drain trap should be at least 18" away from the wet vent connection.
  4. hj
    Functionally, it is okay. But you are creating a very serpentine drain with all those elbows. SIMPLIFY it by going in a more direct path to the lavatory.
  5. mjsmith0
    mjsmith0 New Member
    Dec 12, 2009
    Los Angeles, CA
    Thanks for the advice. I will try to simplify, but this seems to be about as direct as I can get. The vertical drain is around the corner, and other side of the wall from the sink is a stairwell leading downstairs, so I can't cut across that corner. I mocked up how the framing around the stairwell to give an idea what I am up against.
  6. mjsmith0
    mjsmith0 New Member
    Dec 12, 2009
    Los Angeles, CA
    Thanks Krow. I wonder if that is the right way to go under UPC? I know that is says that vents my connect above the centerline of the drain, but I'm not sure that applies to wet vents or not. In the appendix there is a description of battery vents that require that the connection be horizontal. Darned if you, darned if you don't it seems!:eek:
    "905.2 Where vents connect to a horizontal drainage pipe, each vent pipe shall have its invert taken off above the drainage centerline of such pipe downstream of the trap served."
    "L 6.1.1 - A maximum of eight (8) floor-outlet water closets, showers, bathtubs, or floor drains connected in battery on a horizontal branch drain shall be permitted to be battery-vented. The drain from each fixture being battery~vented shall connect horizontally to the horizontal wet-vented drain branch. The horizontal wet-vented branch drain shall be considered as a vent extending from the downstream fixture drain connection to the most upstream fixture connection."
  7. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    The wet vent part needs to be on the branch, not the line
  8. mjsmith0
    mjsmith0 New Member
    Dec 12, 2009
    Los Angeles, CA
    Oh, I got it now. I think I need to go back to the drawing board to figure out how to get this to work in the space I have.
  9. Terry
    Aug 17, 2004
    The entire wet vent portion should be 2" pipe.
  10. hj
    The "wet vent" can be ANY configuration, as long as the sink is "washing" the horizontal pipe. What is that short piece of 2x doing? IF it can be thrown away, then just install a combo pointing directly to the lavatory and connect the shower to the end of it, even if THAT requires additional elbows. There are several better ways of doing it than what you have configured.
Similar Threads: venting shower
Plumbing Forum, Professional & DIY Advice Shower venting details/ dry run Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Question about wet venting a toilet and shower Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Venting a walk-in shower question Apr 22, 2016
Plumbing Forum, Professional & DIY Advice Advice for preventing toilet from backing up into shower trap Feb 20, 2016
Plumbing Forum, Professional & DIY Advice Venting a shower trap arm, also 3" p trap? Dec 28, 2015
