Wet tile around the toilet
Discussion in 'Toilet Forum discussions' started by Custom Resource, Aug 23, 2007.
  1. Custom Resource
    Custom Resource New Member
    Aug 23, 2007
    We installed a brand-new toilet in an apartment that is not yet occupied (I mention this to rule out frequent flushing as an issue). The floor is this gorgeous white marble tile, the top of which has been sealed. However, around the toilet base the marble is darker in a halo radiating from where the wax ring is located. Though not wet to the touch, it looks as though the toilet is leaking slowly out into the tile and grout. Does this signify a common leak? Is the toilet improperly seated?
    Could the master plumber we used have screwed this up?
  2. jadnashua
    Unless the toilet is flushed, or there is an internal leak, there isn't normally any water in the drain line. Sounds like you may have an internal leak, so it could be a defective toilet. Another thing, but normally only if it is used, is condensation. But, if you don't flush it, it doesn't get/stay cold enough to have any condensation and dripping. Last, if it does leak when flushed, once things get wet, it can take as much as 10-days for the tile to dry out. I say that from my limited experience when setting tile - the moisture from the thinset will discolor some tile for that long until it sets and dries out.
    Sounds like you need to remove the toilet and see what's happening.
  4. Custom Resource
    Aug 23, 2007
    I was just hoping some grizzled veteran plumber would reply with something like "Darker grey ring around your toilet in a white marble floor, you say? Well that's a standard 'moisture halo'. It's a sign of an excellent installation. It occurs during the first two months of a toilet's life and will clear up naturally."
    I figured our guy is gonna have to come back. Darn.
    And as for its gorgeousness, well, it just makes it that much more frustrating to see something like wet tile around the toilet.
  5. Old Dog
    Old Dog G.C. 22+ years(in 3 states)
    Aug 4, 2007
    Hawaii
    wet tile...
    Did you install a new angle stop and supply line?I had a job where the angle stop leaked just alittle after being disturbed.The copper supply line was on a little bit of an angle .water ran back into the wall and dripped down,worked its way under vinyl floor and discolored the vinyl.
    BTW, did you use white thinset under the marble?I've seen grey thinset
    "ghost" thru white marble tile as it was drying.Didn't go away.Had to be removed and redone.(I had a very unhappy homeowner,very very unhappy tilesetter!!)
  6. Custom Resource
    Aug 23, 2007
    Yes, white thinset under tile... all the tile was done at once so it's definitely wetness I'm looking at. And yes, new angle stop and supply line to the wall (no further). It's definitely water coming from the base of the toilet and definitely not wetting any exposed surface. I'm seeing the wet tile through the sealed top surface, which makes me really nervous about the extent of damage if we don't deal with it soon.
    I understand the homeowner's pain-- but tilesetter should be thrilled there was more work to do... in theory.
  7. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    both wax ring and flapper leak, at the same time. That is my guess. Turn off the supply to the toilet and see what happens.
    david
  8. Old Dog
    Aug 4, 2007
    Hawaii
    pain...
    Tilesetters mistake...tilesetters pain!(financially)
Similar Threads: tile around
Toilet Forum discussions Tile not level around Toilet. Jul 26, 2009
Toilet Forum discussions Tile has Gap around Toilet May 5, 2007
Toilet Forum discussions new tile under flange or around it? Jul 22, 2006
Toilet Forum discussions Sani Seal with Offset Flange 1/4" Above Tile Floor Jan 5, 2017
Toilet Forum discussions Uneven tile so flange does not sit on top Dec 19, 2016
