Snailcrusher
Hi All,
I have a 86 Gallon Wellmate Fiberglass Pressure Tank for my Well. Model WM-25-WB. Installed August 2010. It has a Bladder Air Cell inside, not a Diaphragm.
In December 2015 I began noticing low pressure in my house. That lasted for about two weeks till one morning I woke up with no pressure at all.
I called a plumber and he discovered that the Relay Switch for the Well Pump was fried and that the Pressure tank was water logged.
He replaced the Relay Switch, drained the Pressure Tank and Re-Pressurized it with air.
Now, in April 2016 I am again having low pressure in my house. So, I drained the Tank myself and Re-Pressurized it. Water pressure is OK for now.
I am considering getting a new Pressure Tank.
I live on a farm and use a lot of water for irrigation and to water the animals.
I have several questions.
Is Wellmate a good choice? I have been dealing with their Technical Help Desk and they are not very knowledgeable.
What are the Pros and Cons between a Bladder Tank and a Diaphragm Tank?
What are the Pros and Cons between a Metal Tank and Fiberglass Tank? My climate is very rainy and damp and the Tank is in a very small room with little ventilation. So I concerned about rust.
What brands of Tanks would you recommend?
What brands of Tanks would you definitely not recommend?
Please chime in, I need to make a decision soon.
The more opinions the better
Thank You
Thank You
