Wellmate pressure tank leaking
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Karljr, May 31, 2012.
  1. Karljr
    Karljr New Member
    May 31, 2012
    Oakville, WA
    I have a 6 year old Wellmate pressure tank WM25-WB that is leaking around the plastic cap on top of it. The leak is between the fiberglass and the plastic cap not inside the cap where the shrader valve is located. Can this be repaired? If yes how?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I don’t think it can be repaired. 6 years? That is one year past the five-year warranty period. Probably just a coincidence. :)
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    It's done trash it.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I'm not as familiar with the WM25-WB as these two experts, but I would not roll over so easily. It's my very frugal nature. Perhaps there is a slight deformity in the composite material that makes up the sealing surface that could be touched up with fine sandpaper on a hard block.
  6. Karljr
    Karljr New Member
    May 31, 2012
    Oakville, WA
    Thanks for the reponse. My plumber is saying it's toast but I'll tear it apart and look at it just for fun. I'll let you know if I am successful.
  7. Karljr
    Karljr New Member
    May 31, 2012
    Oakville, WA
    Thanks for the response. I am hearing the same thing from everyone.
Similar Threads: Wellmate pressure
Pumps and Tanks Well Forum & Blog. Water is life. Wellmate Pressure Tank Apr 25, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Need advice about replacing Wellmate Pressure Tank Apr 6, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Question about WellMate pressure tank Jul 28, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Problems with Wellmate SP-series pressure tanks? Jan 3, 2013
Pumps and Tanks Well Forum & Blog. Water is life. The Quick Connect fitting on my new WellMate pressure tank leaks Aug 14, 2010
