Well water test results
Discussion in 'Pumps and Tanks Well Forum & Blog' started by WV Hillbilly, Oct 2, 2008.
  1. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    Total Alumimum - ND mg/l PQL-0.04 MCL-(0.05)
    Total Barium - 0.56 mg/l PQL-0.05 MCL- 2.0
    Total Iron - 0.12 mg/l PQL-0.01 MCL- (0.3)
    Total Alkanity - 209 mg/l PQL-2.81
    Turbidity -34 N.T.U. PQL-0.22
    E. coli Absent
    Total Coliform Present
    Total Chloride -21.2 mg/l PQL-0.15 MCL- (250)
    Total Manganese - 0.10 mg/l PQL-0.01 MCL - (0.05)
    Total Organic Carbon - 4.22 mg/l PQL-0.1
    Total Dissolved Solids - 296 mg/l PQL-10 MCL-(500)
    Total Surfactant -ND mg/l PQL-0.2 MCL- (0.5)
    Field pH - 7.36 S.U.
    About a month ago my brother-in-laws well water suddenly appeared to be full of soap powders . The water was white & milky looking & there was even white grit that looked like laundry detergent . We live in an area that has a lot of natural gas wells & more being drilled everyday . There was a gas well drilled not far from his house at the same time this happened to his water well . There is some type of soap used by gas well drillers . These test results are from his water well , not mine . My question is this , do any of these test results reflect soap being in his water & if so which one . Also if none of these tests would reflect soap being in the water , what test should be requested that would ? The company that drilled the gas well had the test done . Any other comments on these test results would be more than welcome . Thanks in advance .
  2. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    You should test for phosphates. Phosphate is an ingredient in many soaps.
    sammy
  4. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    I'd find out how deep the gas well is and put one in myself. :D
  5. WV Hillbilly
    Aug 1, 2008
    WV
    There is already a gas well on his property & one on mine . A couple weeks ago they was marking a new location on my property to drill another one . We both get free gas from the wells on our property . My father-in-law owns the mineral rights & gets nice checks from the gas these wells produce . The average gas well depth in my area is about 5,000-5,500 ft.
  6. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    You need to find out what chemical(s) are used in drilling and get the manufacturers MSDS sheets and specifically test for these chemicals. Testing for soaps is just a poke and hope process and you will more than likely miss something.
  7. Southern Man
    Jun 27, 2008
    North Carolina
    Damn I'd covert my truck to CNG. It would pay for itself in 6 months.
  8. WV Hillbilly
    Aug 1, 2008
    WV
    I have been doing some research into that . The home filling stations that I have been able to find says you can't use wellhead gas . I don't see why not as all my appliances work fine on it . My furnace , range , water heater & clothes dryer all work fine . I have a backup generator that I can & will buy a conversion kit for . The kit for the generator runs off a gas line , not CNG . I'm not giving up on CNG for my vehicles yet .
  9. Southern Man
    Jun 27, 2008
    North Carolina
    My guess is that it has more do do with taxation then physio-chemical reality. You're not supposed to fill your truck from your home heating oil tank either, even though its the exact same stuff minus some red dye.
    What is the BTU/ cubic foot of the well gas vs the gas line? Even if it were low it seems to me that you could just burn more of it. I'd talk to the vehicle conversion folks to see what they say.
Similar Threads: water test
Pumps and Tanks Well Forum & Blog Well Water dirty brown after home inspector's flow test Jun 28, 2016
Pumps and Tanks Well Forum & Blog - NO WATER: new JET pump, lines test good?? Help! May 23, 2015
Pumps and Tanks Well Forum & Blog Pressure Tank Tested - Still Low Water Pressure Apr 21, 2015
Pumps and Tanks Well Forum & Blog water (well) test results Apr 16, 2015
Pumps and Tanks Well Forum & Blog Help! Math test on water pumping costs Apr 7, 2015
