denalitl
Water Test Kit-90 results:
Boron - .15 ppm
Calcium - 130 ppm
Iron - 2.60 ppm
Magnesium - 128 ppm
Manganese - .499 ppm
Potassium - 3.7 ppm
Silicon - 12.1 ppm
Sodium - 107 ppm
Strontium - .6 ppm
Sulfur, total by ICP - 88 ppm
E.coli - Negative
Coliform - Positive
Alkalinity - 480 ppm
Bicarbonate - 479 ppm
Carbonate - 1.13 ppm
Chlorate - 1.6 ppm
Chloride - 300 ppm
Color - 40 c.u.
Corrosivity, Langelier Index - 0.6 s.u.
Corrosivity, Ryznar Index - 6.2 s.u.
Hardness - 852 ppm
Hardness (gpg) - 49.7 gpg
PH - 7.4 s.u.
Silica - 25.9 ppm
Sodium ads. ratio, adjusted - 1.88
Sodium adsorption ratio - 1.59
Sulfate - 258 ppm
Turbidity - 31.5 ntu
Total Dissolved Solids - 1880 ppm
We might also have iron bacteria, when I open the outside faucet the water comes out a very dark orange color for a while. I have also noticed the inside of the pluming to be orange and slimy. The water smells and tastes really bad and it spots everything.
I have a five year old Fleck 9100sxt dual tank water softener system, each tank is 96,000 capacity with 3 cuft of 8% crosslink resin. I have a 20" BB 50 micron filter before the system. For drinking water we have a R O system.
There are six residents in the house with 3 1/2 bathrooms. The water comes from a deep well with 1 1/2 horsepower submersible pump, 40 psi on and 60 psi off and 118 gallon pressure tank. Flow rate is about 25 gpm.
The master settings i have right now for the softener are per Dittohead's recommendations from my other thread https://terrylove.com/forums/index.php?threads/9100sxt-wont-refill-brine-tank.68778/
Master settings are as follows :
DF - GAL
VT - dF1b
CT - F1
NT - 2
TS - U2
C - 60,000
H - 55
RS - SF
SF - 00
DO - 14
RT - 2:00
BW - 10
BD - 60
RR - 5
BF - 20 (set high due to iron load)
FL - t0.7
Most likely will need to reset again.
Thank you
Boron - .15 ppm
Calcium - 130 ppm
Iron - 2.60 ppm
Magnesium - 128 ppm
Potassium - 3.7 ppm
Silicon - 12.1 ppm
Sodium - 107 ppm
Strontium - .6 ppm
E.coli - Negative
Coliform - Positive
Chlorate - 1.6 ppm
Chloride - 300 ppm
Color - 40 c.u.
Hardness - 852 ppm
PH - 7.4 s.u.
Silica - 25.9 ppm
Sulfate - 258 ppm
DF - GAL
VT - dF1b
CT - F1
NT - 2
TS - U2
C - 60,000
H - 55
RS - SF
SF - 00
DO - 14
RT - 2:00
BW - 10
BD - 60
RR - 5
FL - t0.7
Thank you
