Karl in NY
I have a new well, northern NY, by canadian border...both neighbors have ~40' deep wells, but my driller didn't hit water until 125', and it turned out to be over 20-gpm and artesian, occasionally rising to over top of casing.
I plan on setting the submersible pump at about 120', and wonder what to expect for water temp. from that depth, and whether there will be any difference, summer vs. winter?
I'm going with a tankless electric water heater, as I don't want propane within the house, although I will use it for a whole-house backup generator.
The question is: if water temp. will be nearly constant, should I insulate the poly-pipe( about a 60' run from well to house) as that line will be buried just below frost line (48"). I'm thinking that the water from 120' will be much warmer in winter than the ground is at 48", and thus insulation could increase the yield of a smaller tankless electric water heater.
No opportunity to test my theory until trench from well to house is already back-filled, then, too late to insulate.
I tried doing searches to determine ground water temp. at those depths, in this climate, without much luck so far.
