well water sediment filter question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bronzemaxell, Jul 26, 2010.
  1. bronzemaxell
    bronzemaxell New Member
    Jun 24, 2010
    earth
    i went to lowes and saw they have the whole house whirlpool brand sediment filter with 1" thread, so i bought one, and to try.
    is it a good idea to put a sediment filter before or after the pressure tank (120 gallon)?
    i am also trying to install the Calcite filter with 2510sxt control valve and water softner with 2510 sxt control valve. does the AN filter or water softner also have built-in sediment filter?
    it is the first time i've seen how the well water looks like through the clear plastic sediment filter housing after pump from well. initially very muddy, like coffee, then it clears up.
    my concern is after a couple time of pumping, the sediment filter is basically brown, and i can see sand being collected in the bottom of the filter housing, and i am afraid the filter will restrict the flow of water from pump, and putting extra work load on the pump.
    [​IMG]
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I would probably install it after the pressure tank.
  4. bronzemaxell
    Jun 24, 2010
    earth
    ok, thanks for your advice
    i am thinking to installing a chemsorb sediment filter with auto backwash 2510 control timer after my pressure tank, between the calcite filter and water softner.
Similar Threads: water sediment
Plumbing Forum, Professional & DIY Advice Sediment in my water. Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Sedimentation Tank for Domestic Well Water System Dec 30, 2016
Plumbing Forum, Professional & DIY Advice Sediment in hot water on tankless system, from failing storage tank? need advice & referral in 98004 Apr 10, 2015
Plumbing Forum, Professional & DIY Advice Gas water heater-- sediment trap / drip leg length Feb 22, 2015
Plumbing Forum, Professional & DIY Advice Water help needed - Sulfur smell, bad taste, black sediment Jan 28, 2015
