well water pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ugabulldog, Apr 15, 2012.
  1. ugabulldog
    ugabulldog Member
    Nov 27, 2007
    Northeast GA
    How much psi should I have from well to tank, the same as my cut in and out settings?? If this helps, I have a submersible pump about 240' deep, well is about 380' from house, 1" pvc. Tank cut in at 30 psi, off at 60 psi. The reason I am asking is I have a pressure relief valve at top of well, it is leaking when pump runs, I have adjusted it all the way up to 175psi and it still leaks when pump runs.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Either your pressure relief valve is bad, or you have a Cycle Stop Valve and the pressure relief needs to be moved to a point after the CSV.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    From another thread I was lead to believe that ugabulldog has a prefilter and a micronizer to aerate the water for iron filtering. A micronizer can be a significant flow restriction and can raise the pressure at the wellhead. How much, I don't know. If the PRV worked up until now and just recently started popping off, I would suspect it is either bad or the prefilter/micronizer is partially clogged.
  5. ugabulldog
    ugabulldog Member
    Nov 27, 2007
    Northeast GA
    Hi LL, I cleaned the filter, it was very durty but relief valve is still leaking, can't really check the micronizer, but it is still sucking air....thanks again for your help. I might ry another prv or just cap off.
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    Put a pressure gauge where the prv is and see what pressure you are dealing with.
Similar Threads: water pressure
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Yesterday at 7:40 AM
Pumps and Tanks Well Forum & Blog. Water is life. Low water pressure on well system Jan 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie help with water pressure issues, thinking of a CSV Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure trouble shooting Nov 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Complete redo of water plant - replace pressure tank with CSV Oct 17, 2016
