well water discolored after power outage
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by alleycat, Apr 6, 2007.
  1. alleycat
    alleycat New Member
    Oct 29, 2004
    Illinois
    Hello all
    We got socked with heavy snow here Tuesday night, and the power was out for 20 hours. When it came back, our well water was brown. It seems clear now, but should I be testing it? Our well is 2 years old and 450+ feet deep.
    Thanks for any responses!
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I would doubt there is any need for concern. The period of dormancy possibly allowed a bit of settling that was later lifted out during a higher-than-usual demand when your overall system was replenished.
  4. Gary Slusser
    Retired
    If there wasn't but 10-20 gals or less of the dirty water, then the cause was probably sediment from iron in the water in the plumbing coming loose when you got water running again. The cause is due to the water lines being depressurized for 20 hrs and that allows sediment to come loose to be flushed out later.
    That would happen for sure if you have a leaking check valve in/on a submersible pump and it allowed air into the plumbing as water ran back to the well.
Similar Threads: water discolored
Plumbing Forum, Professional & DIY Advice Hot and Cold PEX Connections to the Water Heater from Below Thursday at 7:14 PM
Plumbing Forum, Professional & DIY Advice Manual versus automatic water addition for a steam system Wednesday at 6:02 AM
Plumbing Forum, Professional & DIY Advice Low water cut off series 67 Wednesday at 5:55 AM
Plumbing Forum, Professional & DIY Advice Where to place Tankless Water Heater Condensation Line Wednesday at 12:10 AM
Plumbing Forum, Professional & DIY Advice Add garden water valve/spigot to irrigation main line Wednesday at 12:09 AM
