well water discoloration
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by cjreed, Dec 13, 2009.
  1. cjreed
    cjreed New Member
    Dec 13, 2009
    USA
    Hi,
    I just built an ice skating rink for my kids, and filled the rink with water this afternoon. I ran the water for about 1 hour out of the garden hose. This evening my wife ran a bath for the kids and the water is discolored like a very diluted tea color. (and yes, it was that way before the kids got in. :)
    I figure, that from running the well filling up the rink, this did something to discolor the water? Did I run the well low, or damage the pump or liner? The pump is only two years old this Thanksgiving. We have about three inches of snow on the ground and it has been melting over the last few days, and we've had some rain this afternoon too. Don't know if this is the problem, but it seems that there is a connection between me running the well since I've never have discolored water until tonight.
    Anyway, and thoughts would be appreciated. Thanks, CJ
  2. Waterwelldude
    Waterwelldude Well driller,pump repair. and septic installer
    Feb 11, 2009
    Texas
    From my experience, this is not a big deal. The amount of water you used for the rink, changed the normal coarse of the water flow.
    All you did was knock some minerals off the pipes when the water went back to its normal flow.
    It should clear up in a few minutes or an hour or so.
    I don't think you have anything to worry about.
    Travis
  4. Gary Slusser
    Retired
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Is that the right thread? It's the one on control boxes ?
  6. cjreed
    cjreed New Member
    Dec 13, 2009
    USA
    Thanks for your reply Travis. This morning we're still getting the discoloration. It's the same very diluted tea color. We've used the shower several times, flushed toilets as normal and it appears to be the same color. I'll give it a few days to clear, and then I'll start getting concerned.
    What are the signs of a low well? Would the water become discolored? The well is about 15 years old, the pump is two years old.
  7. Gary Slusser
    Retired
    ummmm I have no idea now why I posted that link to that thread. I had to be thinking I was reading another thread. I'll be OK later.
  8. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    First coffee, then type ;)
  9. Stonecutter
    Stonecutter Natural Stone
    Nov 5, 2008
    Maryland
    CJ,
    I get that kind of discoloration often after using a lot of water. My well is deep, around 600' IIRC. It is drilled this deep in order to create a reservoir to compensate for a very low groundwater output.
    I had my pump replaced a couple years back, and watched the well guys. The amount of rust looking sediment on the upper 100 to 150 feet of pipe was pretty gross. The well guys acted like this was pretty typical in a steel casing deep well.
    Anyway, I attribute the colored water after high usage to this sediment on the walls of the well & drop line becoming dislodged as the water level goes up & down.
  10. cjreed
    cjreed New Member
    Dec 13, 2009
    USA
    Thanks guys. The water did clear, and just as you said aquaman, it cleared after I ran the well the following to fill the rink some more.
  11. nofears67
    nofears67 New Member
    Mar 4, 2009
    Possibly the large demand to fill the ice rink lowered the level of your well down such that water was cascading down the casing. This cascading of water could either stir up sediment at the bottom of the well or break off particles of rust, etc from the casing as it dropped down the well.
    Either scenario (or both) would contribute to your issue. Try running your well off to atmosphere at a normal rate (5-10 gpm) to see if this helps remove the suspended particles and colored water from your well.
    BTW, what are your normal pump well demands and what rate do you think you were running while filling the rink and for how long?
    Can you listen to see if water is cascading down your casing?
Similar Threads: water discoloration
Pumps and Tanks Well Forum & Blog. Water is life. Well water discoloration after unused for 3 years May 22, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Can/Should I install water meter in Single Family well fed system? Yesterday at 7:43 AM
Pumps and Tanks Well Forum & Blog. Water is life. Newb questions about water storage Yesterday at 6:26 AM
Pumps and Tanks Well Forum & Blog. Water is life. 4 Inch Well, Water Full of Sand, Ideas Welcome! Monday at 11:58 AM
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Sunday at 7:40 AM
