well trouble
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dan909, Feb 8, 2012.
  1. dan909
    dan909 New Member
    Feb 8, 2012
    Georgia
    Hey everybody I am new to this forum. I was impressed at the time I came to the forum it said 960 people were currently viewing this forum that's a lot of people.
    I am having trouble with my well the pump will come on and run fine but I am not getting any water. I've done a lot of searching on the net but I haven't found anything that has helped as most of what I found dose not seam to be about my type of well so I will try to explain a little about it.
    I've been told it is an old type well where their is the well itself coming out of the ground with the pump on top. That is where the electric wire connects to a relay that turns the pump on and off a pipe from there has some type of valve there with a pressure gage on the side. I called it a valve but I am not sure if that is what it is or not it has a long screw on top of it that is real tight and don't want to turn although I haven't tried to hard till I find out what it is l am not sure if it is an adjustment screw or a plug. Than I have the holding tank witch is currently empty it has an old type air control valve on the side of it that is a clear plastic unit with a little ball inside (I as told this is the old type). The air control valve has a hose that goes from the acv to the pump.
    So far I have replaced the acv and the hose but s
    till no water.
    I've read that it might need to be primed but I am not sure how to prime or where to prime it at. I have also been asked if it could be out of water. I don't know how deep it is but none of my neighbors are having any problems with their wells and we have had some rain lately and we aren't any serious drought going on here now.
    Sorry for the long post but I wanted to give as many details as I can. Thanks
  2. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    picture would be worth a thousand words. sounds like u have a deepwell jet pump, likely on an older 2" well. is the pump motor verticle or horizontal? did the power go out recently? be sure the new fittings and hose are tight and yes you will need to prime the pump. the valve with the screw u referred to is a pressure regulator.. first kill power. Should be a plug or gauge near the top of it.. remove and pour water in that hole until water stays at the top. may take 1 gallon, or it may take several. then replace the plug/gauge and power on. if u pour more than 15-20 gallons there is a problem. either the foot valve is hung open or the well casing is rusted out. good luck
Similar Threads: trouble
Pumps and Tanks Well Forum & Blog. Water is life. Hartell pump ltp-1 troubleshooting Jan 24, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Old style well not pressurizing, trouble getting water Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure trouble shooting Nov 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. CSV troubleshooting Oct 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Troubleshooting lack of water from well. Jul 20, 2016
