Well test results and brief history
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jeremytl, Jun 27, 2007.
  1. jeremytl
    jeremytl Scientist
    Jan 17, 2007
    scientist
    durham, nc
    Brief history: We had well tested two years ago before we bought house, it tested positive for total bacteria and negative for eColi. It was shock chlorinated and re-tested, with both negative results. We have lived there for 2 years and drink the water heavily, never have gotten sick. The well has NO treatment system of any kind. We have been using a brita filter, which I understand is the opposite of what we should be doing. So, we stopped using the brita filter.
    Last week, I had the local county health department test my well for bacteria and inorganics. Inorganics results won't be back for a couple more weeks. Bacteria results are back ($50 for each analysis). Well tested positive for total bacteria and negative for e Coli. From what I understand after reading your previous comments, I should install a uv filter. I was also planning on installing a "whole house" filter b/c I know I have iron in excess. So, where should each of these filters go? I.e., which order, one before the other, after welltroll tank or before, between pump and welltroll, etc. etc. I have also heard of an under the sink "point of use" filter the guy from my county office told me about. By the way, nice as this guy was, he has been well sampling for 15 years but had limited knowledge about treatment options. I am on a budget and I anticipate I will be installing these filters myself (and the help of my kind father). So I basically need to know the layout and which brands I choose.
    Other house info: Small house, 2 people, one bathroom. Shallow well (60') close to house, pump and welltroll tank under house. Septic tank located less than 100 feet away from well (1965 year built). I also have a question, while I am at it, about my septic tank but i'll post that in the appropriate section. Please know, you guys are very much appreciated!
  2. Raucina
    Raucina New Member
    Jul 30, 2006
    toiletvalveguy
    Seems like another option is to keep using the water since it doesnt seem to bother anyone and keep it out of the reach of infants and guests [?] Ask your guests over the past few years if they ever had a stomach ache after your dinner parties...
    Check the casing and seal for leaks and periodically chlorinate down the hole...
  4. jeremytl
    jeremytl Scientist
    Jan 17, 2007
    scientist
    durham, nc
    Pitcher filters
    are there any pitcher filters (like brita) that knock out the bacteria? Instead of installing an expensive uv treatment etc??
  5. Raucina
    Raucina New Member
    Jul 30, 2006
    toiletvalveguy
    I think the filter pros will say Brita increases the bacteria counts by any errors in maintenance
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    You will kill bacteria and viruses if you get a medicine dropper and add about 1/4 to 1/2 milliliter or cubic centimeter of standard non-scented household bleach per gallon of water. You should not ba able to taste the chlorine level of 1/4 ml per gallon.
    I don't know if the Brita filter contains activated carbon. Activated carbon removes the chlorine. If the filter does not contain carbon, then chlorine bleach in the water will kill bacteria in the filter.
Similar Threads: test results
Pumps and Tanks Well Forum & Blog. Water is life. New well test results any suggestions on treatment? Feb 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. water (well) test results Apr 16, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Confused by well test results Sep 14, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Help interpret water test results Mar 13, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Help with well water test results Aug 17, 2011
