1. derek28
    derek28 New Member
    Jul 24, 2012
    Indiana
    I have some question about well size, I currently have a 2" well with a jet pump and over the last 2 years the water psi has been getting worse when running 2 or more things in the house and i cant deal with it anymore. So i called a well driller and he said that the screen is probably getting plugged up so i asked him about some pricing on a new well and its only $200 more for a 5" well vs a 4". What are some advantages of a 5" well compared to a 4"? And what about pump hp is 3/4hp better than 1/2hp??? The reason im curious is im planning on adding on another bathroom and maybe next year building a pole barn (if she'll let me) and i want to make sure there will be enough water if im washing my truck and the wife is doing dishes and the sprinkler is going in the garden and my daughter flushes the toliet. lol I just want to have enough water is a 4" going to be that much better than my current 2" or should i go with a 5"? He said that he's drilled wells around me and that 125' would probably be the depth so what hp would be best even though the addition and the barn are not there yet? And if I do over size the pump will it hurt anything until the barn gets built?
  2. derek28
    derek28 New Member
    Jul 24, 2012
    Indiana
    After reading alittle on here maybe a 4" with a csv is what i need?
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    For 200 more I would go with the 5”. There are a lot more options available and a lot less problems in the long run with 5”.
    A ¾ HP, 10 GPM series will do 12 GPM at that depth. That should be plenty of water. But the beauty of a CSV is that you can install as large a pump as you want, and still use it like a small one without hurting anything.
Similar Threads: size
Pumps and Tanks Well Forum & Blog. Water is life. Shallow pump intake size May 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Is larger pipe size a problem with a well? Mar 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank size Oct 25, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Wild fire guessing details on pump and on well capacitor start box size Sep 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Size of well seal ? May 31, 2015
