Well Shuts Off
Geolec
North Carolina
Couple of times a week the water just shuts off. Well Breaker does not trip but if I turn the breaker off and back on water starts immediately. Happens using shower or just washing hands. Pressure tank looks like new and the switch is a 9013FSG2. Any thoughts ?
Wallskev
North Carolina,USA
Bad Breaker or Outlet
I have seen this in the Past . It is a one of 3 items based on your wiring.
1. Bad Breaker. The tripped breaker spring is faulty and the switch does not trip.
2. Bad Outlet - Depending on the wiring from the panel to the pump, check for a bad Outlet or if there is a GFI, bad GFI.
If a bad GFI find the cause of the Ground fault .
I woud repalce the Breaker first , a small low cost reapir.
Kevin
Storm rider
Slave to rentals
Nevada
Do you have a pump protector in the circuit? If you do, it may be shutting off the pump. Flipping the breaker off and back on would reset the pump protector.
