Well Setup Question
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Snakebit12, Oct 2, 2012.
  1. Snakebit12
    Snakebit12 New Member
    Oct 2, 2012
    Virginia
    I could use some explanation on the well setup on a property that we recently acquired.
    Here is what we know:
    1. There are two pressure tanks on the property - one is in the basement and the other is in the horse stable.
    2. We have one well.
    3. There are well breakers in the fuse boxes in both the basement and stable.
    4. The stable was built and the well drilled before the house was built.
    4. If you fill the horse tank from the stable spigot, the water pressure drops on both pressure tanks although they each seem to level off around 40 PSI.
    5. When the pump kicks in, the house tank goes to 60 PSI; the stable tank to 80 PSI.
    6. There is a disconnected wire wrapped around the well head.
    Based on this fact pattern, this is my theory:
    1. The wiring in the stable was to run the pump before the house was built so that the stable had water.
    2. When the house was built and the basement pressure tank installed, the wire from the stable was disconnected and wrapped around the well head (I should turn off the well pump breaker in the stable).
    3 A wire was run from the basement pressure tank to the well pump.
    3. A water line was run from the house to the stable through the stable pressure tank to increase the pressure at the stable faucet which is 150' from the house.
    Are my conclusions reasonable?
    John (aka Snakebit12)
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Sounds about right. The pressure tank at the stable is showing higher pressure probably because of friction loss in the line between the two tank. Other than that I don't see any problems. Are you having issues with the way it works?
  4. Snakebit12
    Oct 2, 2012
    Virginia
    No issues per se...was hoping to eliminate the stable tank from the process as it is susceptible to freezing. But I suspect that the water pressure in the stable would suffer so I'll try a heat lamp during cold weather.
    Thanks for your response.
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    It should not be a problem to remove the stable tank. Except that without a CSV, less pressure tank storage means your pump will cycle more often.
  6. bcpumpguy
    bcpumpguy New Member
    Jul 27, 2012
    Langley BC
    if you do not use any water after the pump kicks on do they even out to the same pressure? where is the pressure switch?
Similar Threads: Setup Question
Pumps and Tanks Well Forum & Blog. Water is life. Yet another Storage tank CSV setup Question Jan 8, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie question - selecting the right well pump setup (and my idea on what would work Aug 19, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Pump setup question May 23, 2013
Pumps and Tanks Well Forum & Blog. Water is life. New well setup questions Oct 2, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Do I need a well-point for preexisting cased well? Setup questions, PVC alternatives? Jul 19, 2012
