1. rick.a
    rick.a New Member
    Jan 11, 2007
    Palmer, Massachusetts
    I have a dug well (don't laugh, it has great water...and came with the place). It has a concrete cap about 3ft in diameter with a hole about 3inches in diameter for the drop pipe from the jet pump. The hole not sealed, so bugs and other junk can fall in. I have heard about well seals but not seen any. Is there one for this type of setup, and can it be installed in my hole without having to lift up the concrete cap? The cap is several inches thick and very heavy.
    As soon as the Spring thaw comes I will be putting the pump back in and want to do it correctly. The prior install was a mess.
    thanks,
  2. Gary Slusser
    Retired
    I don't know of any seal for it but you may be able to make something.
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Made by Fernco or whomever, there are fluted rubber bushings for installing various pipe sizes into larger fittings or holes, and I cannot imagine your having much difficulty finding a 3" x (your pipe size) one that will work. A little food-grade grease or cooking oil, my personal favorite, will assist your sliding the bushing down your pipe toward the hole, and some butyl sealer applied to the flutes/ribs on the outside of the bushing will help to assure its seal in the concrete hole without forcing the butyl into your well.
  5. rick.a
    rick.a New Member
    Jan 11, 2007
    Thanks Leejosepho. I will look for such an adapter. I just wanted to be sure that there wasn't something designed for this that I missed.
  6. Rancher
    Rancher Guest
  7. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Rancher is correct. Well seals are normally only used in warm climates where the well is terminated above ground and a pitless adaptor isn't needed. The 3 X 1" or the 3 X 1-1/4 would likely work for you.
    You can see one here.
    bob...
  8. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    Seems to me that I saw a CSV/well seal combo set somewhere..... or maybe I was thinking of something else.......(-;
    Ron
  9. rick.a
    rick.a New Member
    Jan 11, 2007
    Hi Bob, A warm climate well is really what I have hear in Massachusetts, since we use it only in Summer. After I get a good measure of the hole, I'll order one of the seals.
    thanks.
  10. speedbump
    Jul 15, 2005
    Riverview, Fl.
    You could have seen them at my house Ron :)
    bob...
Similar Threads: seal
Pumps and Tanks Well Forum & Blog. Water is life. Cup seals always need replacement after year's time. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Seal Cap and/or Drop Pipe Supports/Hangers Dec 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Please identify (well seal?) Dec 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Does anyone make/sell 6.5inch well seals? Sep 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sewer evacuator lid - how to seal? Jun 21, 2016
