Well Seal Electrical Conduit
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by akcooper9, Sep 30, 2013.
  1. akcooper9
    akcooper9 Member
    Sep 30, 2013
    North Texas
    How are you guys protecting the wire that powers the pump after it exits the well seal? Here is how mine is. Any suggestions?
    [​IMG]
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    That double-jacketed wire is good stuff. You probably don’t need anything else for protection. You could just silicone up the gap in the seal. However, the proper way would be to slide a rigid nipple over the wire, and screw it into the blue well seal. Then use a changeover from the rigid nipple to seal tight conduit and run the flexible conduit to the box.
  4. akcooper9
    akcooper9 Member
    Sep 30, 2013
    North Texas
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    Ha Ha that’s pretty funny. My wife says my problem is so many things in the pump business have names that are phallic. A crossover sheet for pump jargon would have to be rated X.
  6. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is funny.
    I got in trouble when Terry changed his Fav Icon to the heart.
    She wanted to know why I was at a dating site.
    Have Fun Everyone.
  7. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Most of those well seals come with rubber inserts and a jam type nut to seal the wire. A lot of guys use silicone like Valveman said or electricians dum dum
  8. akcooper9
    akcooper9 Member
    Sep 30, 2013
    North Texas
    Im gonna try the 'ridged nipple' first as it doesn't appear I have a lot of room to play with due to the 'sucker' tube in the middle.
    Im just trying to get my equipment set in a permanent long lasting place. But so far, we have enjoyed the well a great deal.
  9. akcooper9
    akcooper9 Member
    Sep 30, 2013
    North Texas
    Thanks for the help guys. I got everything set how I wanted it.
    One question after using the rigid nipple and the seal tight conduit, I get a sucking noise from the blue cap on the well seal. Is that normal? I was thinking about getting another rigid nipple and some other fittings to make a "J" so it can breath. Thoughts?
    [​IMG]
    [​IMG]
    [​IMG]
  10. craigpump
    Apr 12, 2012
    Yep, wells need to breathe.
    The sucking sound you hear is the vacuum being created in the well when the pump is running and the water level is dropping. When the pump shuts off the water coming in will displace the air.
  11. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I am thinking about freezing in North Texas. Maybe you are not in the colder parts. [​IMG] I am also curious what the grey tube is on that manifold with the gauge. I figured out that the box is your pressure switch, and the tubing to that box is electrical. But that leaves a water tube doing something.
  12. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    They call that a Water Hose in Texas.
  13. valveman
    Mar 15, 2006
    Lubbock, Texas
    That little blue plug opposite where the wire goes through is for a vent. You need another rigid nipple, two elbows, and a screen. This way the vent is pointed down to keep out rain and the screen keeps bugs from getting sucked in.
    The garden hose is how a lot of people irrigate the yard. If you remove the check valve on the discharge side of the well head and replace it with a CSV your pump system will last longer and be more “permanent”. The extra check valve will cause problems sooner or later and the CSV would keep the pump from cycling on/off to death while you are using a garden hose.
  14. akcooper9
    akcooper9 Member
    Sep 30, 2013
    North Texas
    Yup, its a water hose. Im using it until I get a chance to rent a trencher so I can run some more lines. In a perfect world, I wont even use that hose bib
    VM we've talked on the phone before. I think a CSV is the way to go. Of course I know more today then I did a few months ago when I had the well done. Do I just PM you for the secret password on pricing :)
    Also you're saying the CSV replaced the brass check valve? That seems so easy.
    As for the freezing questions, the line under ground to the pressure tank is below the frost line and Ill be covering the well head and pressure tank before winter hits. Still debating on boxes with insulation for each or whats the best method to going about protecting them.
  15. valveman
    Mar 15, 2006
    Lubbock, Texas
    With a CSV running a garden hose is OK because the pump will not cycle as long as you are using more than 1 GPM. Yep removing the check valve at the wellhead is good and would be a great place to install the CSV1A.
  16. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Call 800-652-0207 and ask for Karen. I think she will sell you a CSV with a credit card!
  17. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I would also install lightning protection, I did not see any ?
    It will save pulling the pump. North Texas has some neat lightning shows. Some can start and end in the bottom of a well.
    Have Fun.
  18. akcooper9
    akcooper9 Member
    Sep 30, 2013
    North Texas
    What do you ya'll recommend?
  19. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
Similar Threads: Seal Electrical
Pumps and Tanks Well Forum & Blog. Water is life. Cup seals always need replacement after year's time. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Seal Cap and/or Drop Pipe Supports/Hangers Dec 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Please identify (well seal?) Dec 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Does anyone make/sell 6.5inch well seals? Sep 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sewer evacuator lid - how to seal? Jun 21, 2016
