indianawell
I was having a well riser installed, with a new submersible pump, and old well pipe lined. The quoted price was 2100. After digging and many other headaches the company said they can not install the riser because the pipe going into the well is 2", now they want to just install a new jet pump. First question does the 2" well truly stop them from installing the submersible pump? Could they not just line the 2" with a 1" plastic pipe? Secondly do you think that the price should remain the same?
So far they have dug two holes in my yard, the first they did not locate the well before hand and were about three feet from where they needed to. The second hole they rented a terramite and actually located the pipes going down to the well.
The well was installed possibly sometime in the 40's or 50's and there is no record of it. The house has set empty for 7-8 years. The old pump was an old jet pump with the two pipes going out toward the well.
If more information is needed I will try my best to answer I have never owned a house on a well so am not very knowledgeable about them.
