Well pump will not build enough pressure to cut out
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Mrk3cobra, Jan 18, 2014.
  1. Mrk3cobra
    Mrk3cobra New Member
    Jan 18, 2014
    Ca
    I have a GE deep well jet pump 1/2 HP. With a square D 30/50 cut out switch. The pump use to cut out at 50 psi and now the pump will only produce 43 psi and does not cut out. The well is only 18 feet deep. I replace the foot valve last year. The pump has two hoses that go down to the bottom of the well.
    How to test if the low pressure is caused by the pump or the ejector at the bottom of the well?
    Thanks, pete
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Clean the jet port. If that fixes it, it was the ejector.
  4. Mrk3cobra
    Jan 18, 2014
    Ca
    Ok I pulled the Injector, what I see is a small plastic funnel on the 1 1/4 line. There is a 1/4" hole at the bottom of the funnel. There is sand packed around the plastic funnel. This is the first time I have seen an injector so I am not sure how they work. Is the water pulled up through the 1 1/4 line through the small hole, and water shot down the 1" hole.
    What do I look for if the small 1/4" hole is open.
    Thanks, pete
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Water is forced upward through that 1/4" hole in the bottom of the funnel. Water goes down the 1" pipe and up the 1 & 1/4" pipe.
  6. Mrk3cobra
    Jan 18, 2014
    Ca
    So if the 1/4" hole is open the injector is good?
    Pete
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    As long as it is not otherwise gunked up with sand. I presume you cleaned the sand out?
  8. Mrk3cobra
    Jan 18, 2014
    Ca
    Does all the water go through the 1/4" hole in the center of the funnel? Does some water go around the outside of the funnel?
  9. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    The old water goes through the 1/4" hole. New water from the footvalve goes around the funnel.
  10. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  11. Mrk3cobra
    Jan 18, 2014
    Ca
    We're do I buy a new injector online, and how to do I size the injector with my well setup.
    Thanks, pete
Similar Threads: pump build
Pumps and Tanks Well Forum & Blog. Water is life. Sta rite 1hp vertical deep well pumping but not building pressure. Jan 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Anyone build a pressure tank/pump house for -20 F? Jun 15, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump Running Not Building Pressure Above 20 Apr 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help! Submersible well pump runs but won't build pressure over 30 psi! Nov 13, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Jet pump slow to build pressure Aug 31, 2015
