Hi, Can You Please Help Me..our Well Water Tank Has 2, I Guess You Would Say Exit Or Intake Holes..?? We Had A Repair Done To The Jet That Goes Into The Ground( To The Water Under Ground) Well I Was Telling The People That Did The Repair That Sometimes The Water Looks Kinda Orange...has Stinks And Tastes Very Bad ...one Hole Is On The Side Of The Tank Right At The Bottom Of The Tank, There Is A Faucet There That You Can Hook Up A Water Hose To. The Other Hole Is On The Other Side Of The Tank And It Is Probably A Little Over A Foot Up From The Bottom Of The Tank....this Is Where The Water From The Ground Goes Into The Tank And Then Goes Into The House. The Guy Told Me It Was Hooked Up Wrong..he Said The Lower Hole Is Where The Water Should Be Entering From The Ground And Going Into The House...he Said The Way It Is Hooked Up Now ,where We Get The Water From The High Side......water Below That Point Mostly Sits In The Tank And Stagnates And That Is Why We Get Orange Nasty Water A Lot..he Said To Either Drain The Tank Often Or Hook The Pipe That Brings The Water To The Pump And To The House Into The Lower Hole(where A Faucet Is Hooked Up To Drain The Tank) I Hope You Can Understand What I Am Trying To Explain Here We Need Help.... Thank You So Much..donna
