Well Pump Size
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Plumber111, Feb 26, 2012.
  1. Plumber111
    Plumber111 In the Trades
    Feb 13, 2012
    North Carolina
    I haven't read all of the posts where pump size is discussed obviously, so it's easier to ask rather than read them all:
    What's they typical well pump size you see or install for your area?
    Thanks.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    The pump gets sized to the delivery of the well and the expected demand. There is no typical pump size. That's why pump manufacturers make a bunch of them.
  4. Plumber111
    Feb 13, 2012
    North Carolina
    I do understand that. However, there is a reasonable standard that I would think you would be seeing for your area. I can tell you right now what is "typical" for a residential here.
  5. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    My rule of thumb is 5 GPM per bathroom. That number can easily change if you have showers with multiple heads or irrigation demands.
  6. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    I dont work on wells but somtimes I turn the power off to well pumps. usually on a 40 or 50 amp breaker if that means anything to those that service them. Pumps are usually within 50' of the breaker panel.
  7. Plumber111
    Feb 13, 2012
    North Carolina
    Thanks. I know that well production, column/static, depth, etc. is needed to customize and get the best efficiency.
    But what HP & GPM pump does that typically translate into for anyone reading's area?
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
    For a 100' deep well that would be a 3/4HP. For an 800' deep well it might be 5HP. Accross the country wells can vary that much in depth, which is why they make so many different size pumps. But I would say the average is a 3/4HP, 10 GPM or a 1HP, 15 GPM.
  9. Tom Sawyer
    Nov 29, 2010
    Maine
    OK, I guess if you held my feet to the fire and made me consult my sales data base we probably put more 1/2hp 7gpm pumps in, in this area around my office than anything else but again, I don't have to go too far north or west and then we can get into much greater well depths, sometimes as much as 800' or so.
  10. Plumber111
    Feb 13, 2012
    North Carolina
    Here we see in the majority 1/2HP-3/4HP around 10GPM with the curve lowering as static drops. A 1HP now and again. I don't remember ever seeing anything above that on residential. Almost zero irrigation here though.
  11. Tom Sawyer
    Nov 29, 2010
    Maine
    I would suspect that if you were to ask Goulds or Grundfos that 1/2hp or 3/4hp. 10gpm are probably their biggest sellers.
  12. valveman
    Mar 15, 2006
    Lubbock, Texas
    In our area a 1.5HP, 20 GPM is the most common, and everyone has an irrigated yard, garden, or both.
Similar Threads: Pump Size
Pumps and Tanks Well Forum & Blog. Water is life. Shallow pump intake size May 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Wild fire guessing details on pump and on well capacitor start box size Sep 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. How do I choose shallow well pump size? Sep 9, 2014
Pumps and Tanks Well Forum & Blog. Water is life. CSV , oversized pump/undersized tank, and other considerations May 25, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Pump size vs tank size May 15, 2014
