wetbar
Hey I have a well pump that is about 300 feet down. I was not getting water so I tested the wires and all were shorted to ground but not a dead short. I was getting about 10M of resistance. I pulled the pump up and did find a bad wire. I replaced the wire and tested the pump while out just for .5 sec or so and it worked. I'm think cool - just for the fun I checked all wingdings to grounds and they were still shorted to ground, but not dead shorted same as before. All the windings look great when test to each other(start to run was 18, run to common was 3, and common to start was 15) but all all them was about 10M or higher to the ground wire and to the metal of the pump. This pump has to be bad, right?
Thanks for the help
Thanks for the help
