Well pump short cycling
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Eilselc, Apr 21, 2011.
  1. Eilselc
    Eilselc New Member
    Apr 21, 2011
    Akron, OH
    Hello, I have a well pump that has started short cycling. I have a Flotec 42 gallon pressure tank that is three years old. I have removed it to check for it being waterlogged and does not seem to be. I have checked the tank pre charge and have it set to 2 psi less than the cut in pressure. Checked it several times since and it always remains constant. I have replaced the pressure switch and it still short cycles. BTW I have a 2 drop jet pump. I am guessing the well is about 90'. The pressure gauge on the pump never drops unless a faucet is opened and doesn't seem to loose prime- by that I mean the water supply is always constant and immediate and never spurts. I have played around with the pressure switch to get it to not short cycle as much, but if the shower is used, the pump will never shut off unless water usage is halted. My guess is my problem is down in the well, i.e. the foot valve. Am I on the right track? Any help would be greatly appreciated.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You say the system does not lose pressure unless someone turns on a faucet, so your foot valve is OK. The tank is holding the air charge so it is OK. Then you say when the shower is used, the pump never shuts until water usage is halted. Which means your pump is running continuously instead of cycling on and off, which is a good thing. I guess I don’t see where you think the pump is short cycling. Is it just bouncing on and off quickly when the pump starts or something?
  4. Eilselc
    Eilselc New Member
    Apr 21, 2011
    Akron, OH
    Yes, the pump would kick on and off extremely rapidly and would not stop. Since playing around with the differential adjustment on the pressure switch, I got it to where it will now only cycle on and off rapidly about 3 or four times and then shut off. Half a turn either way now, the pump will just short cycle really fast or the other way not turn off at all. Hope this helps.
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    I am guessing the pressure switch is mounted on the side of the pump/motor, and you have a check valve between the pump and tank. If that is the case, remove the check valve and the bouncing will go away. Then you will probably find out that the footvalve is leaking, which is probably the root cause of the problem.
  6. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Sounds like a regulator problem, or plugged line going to the switch.
    A bad foot valve would let water go back into the well, You would see the pressure drop when using no water.
    I believe that a check valve between the pump and tank, It would have always done that, Not just started.
    Just my thought.
    DonL.
    "Theory only works in a vacuum" , there are just to many unknown variables in every day life.
  7. Eilselc
    Eilselc New Member
    Apr 21, 2011
    Akron, OH
    Yes the switch is mounted to the side of the pump. AFAIK, there is not a check valve. The outlet comes out of the pump and goes into a sediment filter. The filter is new and even in the bypass mode the bouncing still happens. Then goes into the softener and then pressure tank. Now that I think about it, I have a shutoff valve just after the pump and when I shut it off, the pressure still bounced. Thanks for the help, guess I need to replace a foot valve.
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
    I bet if you move the sensing line to the pressure switch from the pump to the pressure tank, the bouncing will go away.
  9. Eilselc
    Eilselc New Member
    Apr 21, 2011
    Akron, OH
    Sure I will try that. Thanks for the advise. Why do you think this happened, problem did start a couple of weeks after I installed the sediment filter which was about a month ago?
  10. valveman
    Mar 15, 2006
    Lubbock, Texas
    Adding the filter made the pressure switch further away from the tank and added more restriction between the two. The pressure switch should always be right at the inlet to the pressure tank.
  11. Eilselc
    Eilselc New Member
    Apr 21, 2011
    Akron, OH
    Will do, thanks again!
  12. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
Similar Threads: pump short
Pumps and Tanks Well Forum & Blog. Water is life. Water pump stopped. Short cycles then stops. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short cycling, not sure wha to do Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos MQ3-35 booster pump short cycling Nov 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short-cycling. Tank bladder issue? Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Short Cycling Issue Jul 6, 2016
