Well pump setup questions
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Goonberry, Apr 7, 2012.
  1. Goonberry
    Goonberry New Member
    Oklahoma
    I am new to wells and well pumps and hope someone here on the forum could provide some insight or critique what I am trying to do. I have a well on my property that was already there when I build the house and I would like to use it for outside irrigation only. Water level is about 20' from the top of the pipe (6.75" pipe with a 5" pipe inside). I dropped a string down and got to about 200 feet without bottoming out (ran out of string). I would like to keep the project as cost effective as possible, so I want to use a 4" submersible pump dropping it about 100 feet (1/2 hp 10-12 gpm. 2 wire) using 1-1/4" 160 psi poly pipe with a long brass barb connection with no safety rope or torque arrestor. I would size each of the irrigation zones for 10 gpm at 40 psi to avoid any excessive pump cycling.
    I would like to do this without a pressure tank? What type of pressure protection if any is needed? Could I still use a pressure swith with a tankless setup?
    I would have about 8 zones and water each zone for 30 minutes twice a week.
    Would a red lion/little giant pump be sufficient for this setup or are they junk like most of the box store brands?
    I have read hundreds of posts on the forum and know that there are numerous people on here with extensive knowledge and experience so any advice would be greatly appreciated.
  2. masterpumpman
    masterpumpman New Member
    729
    Virginia Beach, VA
    You're on the right track and yep Big Box store pumps are usually junk but cheap and they do work. I'd recommend installing a Pside-Kick. The Pside-Kick includes all that you will need to give you constant pressure for your irrigation system while extending the life of your pump. Go to http://www.cyclestopvalves.com/products.html to see the Pside-Kick. If you can't find it in your area contact Cycle Stop Valves they can assist you. NOTE: Don't purchase a VFD type pump!
  3. Goonberry
    Oklahoma
    Porky.
    thanks for the input. I have some budget constraint so I will procede without the pside kick and then hopefully add it in the future for a more stable pressure and less cycling of the pump
  4. valveman
    valveman Moderator Staff Member
    4,382
    Lubbock, Texas
    If you can match all the zones to the pump, then use the pump start relay in the sprinkler timer box to turn the pump on and off. You can't use a pressure switch without a pressure tank.
  5. JPat
    JPat New Member
    14
    Johnsburg, Il
    Some type of pressure relief should be installed. When the zones switch you will get an increase of pressure and dead head the system against your sprinkler valves, over time they will fail prematurely due to the excessive pressure.
  6. valveman
    4,382
    Lubbock, Texas
    Ditto on the pressure relief!!! It will help with spikes between sprinklers zones. But most important, it will keep the motor from burning up when the gophers eat the wires to the sprinklers, the timer didn’t know it and started the pump anyway.
  7. Goonberry
    Oklahoma
    excellent. I will match the zones and install some type of pressure relief valve. No gophers around here just prairie dogs :D
  8. Goonberry
    Oklahoma
    Running into a small issue when trying to find a well seal. The i.d of the top of the well pipe is 6-3/4", it flares out at the top. I am not worried about the well being sanitary but would like to attach the drop pipe to the cap and put an elbow on it to keep it all secure. I guess I could cut off the flare out at the top.
    Any ideas? what are my options. No pitless adapter on this.
  9. valveman
    4,382
    Lubbock, Texas
    Looks like just a steel coupling on top. But what is that blue thing in there?
  10. Goonberry
    Oklahoma
    Its some sort of insert just shy of 5" ID. Not sure how deep it goes.
Similar Threads: pump setup
Pumps and Tanks Well Forum & Blog Garden sprinkler system jet pump setup? Jun 7, 2014
Pumps and Tanks Well Forum & Blog Newbie question - selecting the right well pump setup (and my idea on what would work Aug 19, 2013
Pumps and Tanks Well Forum & Blog Pump setup question May 23, 2013
Pumps and Tanks Well Forum & Blog Help with setup of Discharge side of Goulds sprinkler pump please Jun 11, 2012
Pumps and Tanks Well Forum & Blog Setup for pumping lake water for irrigation Jun 4, 2012
