Well Pump Running
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by garysivertson, Apr 22, 2012.
  1. garysivertson
    garysivertson New Member
    Apr 22, 2012
    Chesapeake, Virginia
    I have 3/4 HP Sta Rite Pump that will not stop running. I have installed a new 30 to 50 pressure switch and 0 to 100 PSI gage. No leaks in the system. Pressure tube is clear. Bladder tank is set at 27 psi. Pump will buld pressure to 55 PSI and hold that 55 PSI after it is unplugged. Pump will not stop running with all valves shut. You can open the the faucet at the pump pressure will drop down to 35 PSI, close the faucet and the pressure will build back up to 55 PSI and keep running. Attempted to lower the cut out pressure on switch to 45 lbs and pump still will not cut out.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Was anything done before this problem was noted? If the pump will not build over 55, either the pump is shot or there is a leak in the drop pipe down inside the well.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    55 may just be all that pump can do. But you have a 30/50 switch, so the pump should have shut off at 50 PSI. I think you just need a good pressure switch.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Take a screwdriver and pry up on the switch plate in the pressure switch with the pump running. If it shuts off then either
    Bad pressure switch
    Pump is not producing enough pressure to shut it off
    something is wired wrong (probably the pressure switch)
Similar Threads: Pump Running
Pumps and Tanks Well Forum & Blog. Water is life. Jet pump will not stop running after new switch installed Aug 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Circut Breaker Trips - Pump Wire Short, Bad Pressure Tank, or Well Running Out of Water? Jun 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump Running Not Building Pressure Above 20 Apr 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Running a submersible pump with a generator Feb 4, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Short cycling of well pump when no water is running Aug 2, 2015
