It's a 1 hp. Myers Jet Pump and the check valve (new as well) is in the in house line prior to entering the pump (distance about 31 linear inches). The air pressure was 38 lbs before adding the water to the system. The switch (30/50) engages at 39lbs and off at 50 lbs. It's only cycling while using water. The pressure tank is a vertical 20 gal. capacity.
When both small and large screw(s)/spring(s) of the new pressure switch are positioned as the factory set them; the switch keeps rapidly cutting on and off when it is engaged. It will only stop if I tighten the large spring C/W a little less than 1/2 the way down. Afterwards, the pump turns on at 38/40 lbs. and off at 50 lbs., but it continues to run 34+/- seconds during each recharge time (as long as no water spickets are in the on position....eg. flushing toilet). The pump will continue to run longer if water is continually being used (eg. using shower or outside spicket).
All was operating okay for a short while, but last evening, I used the shower and noticed the lights began to flicker in the bath area. I checked the pump and it was stuck in that rapid cutting on and off again loop.
I was under the impression the switch was supposed to engage at 30 lbs. and disengage at 50 lbs. and take much less time time recharging the pressure.
