Well pump only runs when I hold switch manually
Discussion in 'Pumps and Tanks Well Forum & Blog' started by jiggypiggy, Dec 7, 2010.
  1. jiggypiggy
    jiggypiggy New Member
    Dec 7, 2010
    Winnipeg, MB
    I just had a new red jacket pump installed and it has a centripro AS4CB pressure switch on it. I lost power and now pump wont start. I read posts here and other places that say there should be a reset switch thingy on the side, like a little lever that you hold up until there is enough pressure, then it works on its own. Mine does not seem to have that. I took the lid off the pressure control box and found it has power going to some magnet things. Then there is a black piece of plastic that has metal on it. Looks like the magents are supposed to suck the plastic/metal towards it. When I push the plastic to the magents, the pump kicks in and I get water. Just cant get it to kick in once I use up the water in holding tank. Not sure why this would happen. I thought plumber did a good job and its been working (3 days seemed fine). Is there some other type of reset switch? Also, I do not have a pressure guage on the pump.
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
  4. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    if its only been 3 days, i'd call them.. unless he didnt supply the parts in which case he might not have to honor any warranty.
  5. jiggypiggy
    Dec 7, 2010
    Winnipeg, MB
    Just a quick thank you. Works now, needed to get a heater blowing right on pressure switch, works fine now.
  6. ballvalve
    Dec 28, 2009
    northfork, california
    The magnetic thingie would likely be a magnetic contactor or motor starter. If the pressure switch is froze up, it will not get a signal to close.
    You probably have a pump control box, which takes the heavy starting load off of the pressure switch. Its a very good system.
Similar Threads: pump runs
Pumps and Tanks Well Forum & Blog Submersible pump does come on and runs until pressure gauge reads 70. Aug 8, 2016
Pumps and Tanks Well Forum & Blog Pump runs then all of sudden stops Mar 29, 2016
Pumps and Tanks Well Forum & Blog Pump only runs when I push the contacts together Feb 15, 2016
Pumps and Tanks Well Forum & Blog Help! Submersible well pump runs but won't build pressure over 30 psi! Nov 13, 2015
Pumps and Tanks Well Forum & Blog Well pump runs constantly and pressure tank doesn't fill May 23, 2015
