well pump noise
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jtdiesel65, Oct 26, 2004.
  1. jtdiesel65
    jtdiesel65 New Member
    Oct 26, 2004
    Hi,
    Our well pump (a submersible) has started to make a bunch of noise (kinda like a grinding) and is using more electricity to start up than it has in the past. It uses more initially then tapers off to where its always been after running a minute or so. We have iron in our water and have a small amount of sediment (or iron) that is collecting on the bottom of the household filter. We've also noticed some green/blue bits or grains on the filter. I was wondering what might be the cause of the noise. I'm thinking the "one way" valve might be bad or the well line may have a leak. Any ideas?
    thanks
    Jon
Similar Threads: pump noise
Plumbing Forum, Professional & DIY Advice Pump noise May 31, 2009
Plumbing Forum, Professional & DIY Advice Sump Pump Thumping Noise/Vibration (video) Feb 20, 2009
Plumbing Forum, Professional & DIY Advice Sump Pump Noise Jun 25, 2006
Plumbing Forum, Professional & DIY Advice Noise from a Flojet pump connected to a hot water dispenser and refrigerator line May 27, 2006
Plumbing Forum, Professional & DIY Advice sump pump noise Nov 3, 2004
