Well pump for Lake water supply
Discussion in 'Pumps and Tanks Well Forum & Blog' started by John Perrie, Sep 23, 2008.
  1. John Perrie
    John Perrie New Member
    Jul 29, 2008
    I am building a cottage in Ct. Water will be pumped from the lake for shower and sink. No water necessary for toilet.
    1. Can a submersible well pump be used in a horizontal position or must it be vertical to function correctly?
    2. Does a submersible well pump require a case or sleeve over it
    to operate correctly?
    I would like to set the pump 12" above the lake bottom.
    The length of 1 1/4 pipe from pump to bathroom is 150'. The rise is approx.25'. Also a cartridge filtration system will be installed. Should the pump size be increased to compensate for the filter?
    Thanks in advance for your assistance.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Yes it can be used horizontally. A sleeve is not necessary but a lake strainer will be. I use my lake strainers as a housing for the pump to keep minnows and leaves etc from plugging the screen on the pump. If your using a cartridge filter, put it after the tank and switch, never between the pump and the switch.
    My 1/2hp Submersible Pumps and the lake strainer:
    bob...
  4. John Perrie
    Jul 29, 2008
    Speedbump, thank you for the help and recommendations.
    One more question. Is a cartridge filter the best way to filter lake water for shower and sink use.
    Thanks again
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Which lake? If you dont mind me asking. Also, you are digging a trench for the power and water line correct?
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    In my opinion, a cartridge filter isn't good for anything. Unless it's large enough to do the job correctly. There are real cartridge filters that can be purchased and used, but you won't find them at any big box stores.
    bob...
  7. John Perrie
    Jul 29, 2008
    lake water supply to cottage
    Speedbump & Chris75 THANK YOU
    Small Lake is located east of Durham.
    The pump was originally going outside the building. The design changed after the water line was installed. Its more practical to use a submersible well pump to avoid outdoor pump freezing.
    To answer your question, no electric was installed in the waterline trench.
    This creates a few questions.
    1. What type of wire for under water application?
    2. AWG size and conduit for water environment?
    3. Grounding requirements
    4. I assume GFI is required.
    5. Required depth of conduit in soil?
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Okay, you first...
    #1, What size pump?
    #2, run well pump wire, but exactly how how far and what is the HP of the pump?
    #3, the well wire will contail the proper EGC (equipment grounding conductor) for the pump.
    #4, no GFCI required,
    #5, at least 18 inches. but why wasnt this buired with the well pipe?
  9. John Perrie
    Jul 29, 2008
    lake water supply
    Distance from electric panel to submersible pump 150' approx.
    The horse power has not been determined, I assume it will be 1/2 H/P.
    The system was originally designed to have a jet pump sitting outside the building in a small enclosure. For this reason no electric was installed in the waterline trench from the building to the lake.
    Thanks Again
Similar Threads: pump Lake
Pumps and Tanks Well Forum & Blog Problems pumping lake water to cottage Aug 23, 2016
Pumps and Tanks Well Forum & Blog lake water pump/tank prssure bounce question Jun 5, 2016
Pumps and Tanks Well Forum & Blog Lake pump pressure relief valve Jul 16, 2015
Pumps and Tanks Well Forum & Blog Lake water pump cracked housing - trying to determine best option with changed needs Apr 29, 2014
Pumps and Tanks Well Forum & Blog Setup for pumping lake water for irrigation Jun 4, 2012
