Well pump controller with flood detector.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dirtmover, Aug 24, 2011.
  1. dirtmover
    dirtmover New Member
    Feb 16, 2007
    Ontario
    It seems like a no brainer to me to have a flood monitor that can interrupt the supply to my well pump when strategically placed sensors detect the presence of water. This would be extremely easy and almost free to incorporate into an electronic pressure switch or CP controller. Is such a device available?
    Yeah I know that water cop product exists but I feel that it would be more reliable to prevent my well pump from turning on in the event of a flood rather than expecting a electro/mechanical valve to function correctly, especially one that is exercised rarely, if ever. I can jut see it being seized 10 years down the road when it is actually needed.
  2. RickK
    RickK New Member
    Nov 29, 2011
    Nevada
    Emergency pressure switch cut-off?
    Yes! I have been scouring the web looking for this. My house has a fully finished daylight basement and I have the sensors for placing in the laundry room, water heater room and pressure tank room but haven't seen how to wire them into the pressure switch. My well service doesn't want to learn anything new so they are no help. I bought the Flood Stop before I really started thinking and had the same concerns that you have. Seems I should be able to wire that relay in to cut power to the pressure switch. Will let you know if I figure it out.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
  5. dirtmover
    Feb 16, 2007
    Ontario
    You can't use this to supply your pressure switch directly. You will need a higher current contactor (say 25A+)
    The pressure switch is the ideal candidate. In fact, why anyone would go to the bother of designing such a device without a water sensor input and shutoff is beyond me. We're talking about adding pennies onto the cost of the device to integrate the required electronics/connectors.
    While we're at it a set of flood contacts that I can use to latch a malfunction condition into my water sourced heat pump and shut it down are also required.
    These features would really differentiate an electronic switch making it something useful rather than just an expensive replacement for a $25 mechanical pressure switch.
    The fact is that I would never entertain an electronic pressure switch unless it provided some major benefit over it's mechanical counterpart. With the above features I would snap one up and at it's current price (around $200) I believe it would be an easy sell to many other well owners.
Similar Threads: pump controller
Pumps and Tanks Well Forum & Blog. Water is life. Creek Pump Controller Sputters & Quits Jun 18, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pump Controller is "weak", yields low pressure Mar 30, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Controller/Pressure Switch Problem...I hope Nov 17, 2008
Pumps and Tanks Well Forum & Blog. Water is life. 2 Houses, 2 Pressure Tanks, 1 pump, 1 controller, 1 pressure switch pro help needed! May 2, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Franklin pump controller info? Feb 15, 2008
