Well problem
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by davismed, Apr 14, 2006.
  1. davismed
    davismed New Member
    Apr 14, 2006
    In the past few weeks while using the water in the house it will stop for a second or two and flow again. We are on a deep well system and when the water stops running there is a click at the relay by the presure tank. Do you have any thoguhts on what it might be?. The system is only about 1 year old.
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It sounds like something that would happen if you don't have the correct amount of air in your tank. You might have too much pressure.
    Shut off your pump switch or breaker and drain the tank by running water until it quits. Then measure the air pressure in the tank. It should be 2 psi LESS than the PUMP START pressure on your pressure switch.
    If it is too high, you can increase the pressure setting on your pump (if the pump has the capability to deliver higher pressure), or you can lower the air pressure in the tank. In any case, you need to get to the condition 2 psi less than start pressure when tank is empty.
  4. davismed
    davismed New Member
    Apr 14, 2006
    Thanks will give it a try.
Similar Threads: problem
Pumps and Tanks Well Forum & Blog. Water is life. Houston, we have a problem. Well sunk? Jan 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure pump problem Dec 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well problems - need help! Dec 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Air Lift Well Pump Problems Nov 23, 2016
