Jarrod318
My water stopped flowing today. I checked fuses and they are ok. The well is in a pit with the pressure tank. The first issue I notice is that I can manually turn the pressure switch on and the pump starts, but the pump turns off after awhile and the switch doesn't open. The pressure tank which is only 3 years old is not pressurizing. I got the water running again but no pressure in the tank even though I have water in the house. This happened earlier today and I was able to get it running for now but I assume that it is just the hot water tank that is full....for now. So, could it be the pressure switch or maybe the pressure tank is frozen since it is VeRY cold in IL today. I have had a heat lamp in the pit facing the pressure tank and switch. Any thoughts???
