Well Mate Problems - Low Pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Crowphonic, Mar 18, 2013.
  1. Crowphonic
    Crowphonic New Member
    Mar 18, 2013
    Nova Scotia
    I hope someone can help! We have a Well Mate Pressure Tank. No problems to date and then this morning we have uber low pressure. I have tried moving the reset lever to introduce more pressure but it didn't work. Am I looking at a reset lever issue or something more substantial. I apologise in advance if my terminology is incorrect - I don't have much of a clue!
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Do you have a submersible pump or an above ground jet pump?
  4. Crowphonic
    Mar 18, 2013
    Nova Scotia
    A submersible. I am thinking it may be the pressure switch - I tested it with a volt tester and one side showed a charge and the other did not. Is this likely to be the issue?
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Is it a 120V or 240V circuit?
  6. Crowphonic
    Mar 18, 2013
    Nova Scotia
    I honestly don't know - though would guess at it being a 240v
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Then you need to trace back to the breaker panel and see if it is 240V and if so see if both legs are hot. It could be a bad breaker.
  8. Crowphonic
    Mar 18, 2013
    Nova Scotia
    OK - I will have my husband check it out tonight. Thank you!
  9. Crowphonic
    Mar 18, 2013
    Nova Scotia
    If it was only a 120v - would only one side be live anyway?
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    On a 120V circuit, one side is hot and the other is neutral so yes, only one side would be "live".
  11. Crowphonic
    Mar 18, 2013
    Nova Scotia
    Okay, so we had an electrician friend come over to test the voltage - he thought it was the switch control capacitor - so we went and got a new one. Installed it, moved the reset to prime and it blew up. Why? I am assuming the last one blew up as well - why are they blowing up?
Similar Threads: Mate Problems
Pumps and Tanks Well Forum & Blog. Water is life. Problems with Wellmate SP-series pressure tanks? Jan 3, 2013
Pumps and Tanks Well Forum & Blog. Water is life. wellmate problems????? Apr 11, 2009
Pumps and Tanks Well Forum & Blog. Water is life. WellMate WM-HP-110 - how to depressurize the system Sep 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Question: what kind of automated valve to shut off feed to cistern? Jun 2, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Wellmate Pressure Tank Apr 25, 2016
