well knocking
Discussion in 'Pumps and Tanks Well Forum & Blog' started by kenpav, Mar 13, 2006.
  1. kenpav
    kenpav New Member
    Mar 10, 2006
    I have a 600 foot deep well running a 1 1/2 pump. There is an additional check valve at the 250 foot level. When the pump shuts off, I here a series of clunks, Two or three, each getting softer. It has done this for years. Now it is starting to bug me. I changed the check valve and the pressure switch. No dice. The pump was also changed a couple of years ago. ANY IDEAS ?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Which check valve did you change?
    bob...
  4. kenpav
    kenpav New Member
    Mar 10, 2006
    The One By The Tanks. Also When The Pump Was Replaced That Valve Was Changed. I Do Not Know If They Changed The One Half Way Down The Well.
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I would remove the one by the tank and I think your clunk will go away.
    bob...
  6. kenpav
    kenpav New Member
    Mar 10, 2006
    It Is Worth A Try. It Is The Eaisest To Get At.
Similar Threads: knocking
Pumps and Tanks Well Forum & Blog Vibration and knocking / shaking from submersible well pump system Aug 25, 2012
Pumps and Tanks Well Forum & Blog knocking in check valve Feb 3, 2006
