Well Issues - Update - Switch Control Exploded
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Crowphonic, Mar 19, 2013.
  1. Crowphonic
    Crowphonic New Member
    Mar 18, 2013
    Nova Scotia
    We deduced that the Switch Control was no longer working. We purchased a new one and installed it. On flicking the reset lever on the pressure switch, this caused the new Switch Control to blow up.
    Any ideas why this would be? Do we need a new pressure switch and guage as well as a new switch control? Do we need a switch control with more hp? The old one and replacement one were .5HP - should we increase to .75HP?
    Is it more likely to be that the pump is broken/jammed and that is why, when resetting, it is causing the switch control to blow?
    Thanks in advance.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If it is a three-wire pump, the control box must be matched to the motor that is on the pump. If there is a dead short in the wiring or the motor, it is possible that the capacitor would swell and burst.
    In a situation like this one would normally start testing by checking the resistance of the start/run circuits and checking for a short between legs or to ground.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I will bet you got two hot legs on the same side of the switch. Power on, switch goes POP!
  5. Crowphonic
    Mar 18, 2013
    Nova Scotia
    Just to update - the pump guys came yesterday and it was a broken wire right at the pump connection. So pump was pulled - is in very good condition thankfully -wire replaced and water flowing nicely again! Thanks for all your help.
Similar Threads: Issues Update
Pumps and Tanks Well Forum & Blog. Water is life. Well pump issues Tuesday at 7:09 AM
Pumps and Tanks Well Forum & Blog. Water is life. Help with well issues Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie help with water pressure issues, thinking of a CSV Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Fiberglass tank issues Aug 9, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Bladder Tank Issues Sep 3, 2015
