Great forum! Thanks for all the expert advice given here. I've been searching for a similar issue but haven't come across my exact problem, so I decided to ask directly.
I moved into a 10 yr old house about 6 months ago and have just encountered a problem with my well water. I was running water from the hose for a few minutes and the water stopped flowing. The water came back a few minutes later. I can reproduce the problem at any time.
I've been troubleshooting based on info read here, but I'm still confused as to the source of the issue.
-By reading pressure gauge on tee, and testing, looks like a 40/60 pressure switch setup. (Square-D)
-Well-X-Trol WX251 tank
-I dont have data on the pump (i'm assuming submersible and deep well, common in this area)
I duplicated the problem this morning and noticed a few things that seemed odd. Pressure was ~62, I turned water on at hose, fell to ~40 and pump kicked on and started to fill tank. Pump shut off at ~50 psi, I kept running the water. PSI fell to ~40 and stayed there for a while, then suddenly went to zero and no more water, I could hear the water draining back in the pipes, etc... (I turned spigot off) The pump came back on a few minutes later and brought psi back to ~62. I ran the water again to get back to 40psi and pump kicked on, I turned off water this time, but at ~50 psi pump shut off again. I kept water off and pump came back on a few minutes later to get to ~62 psi.
So why would pump shut off before 60 psi? Am I running the well dry or could something else be shutting the pump off?
Not sure what to check next...
Thanks for any help you can offer!
Best,
JTP
Best,
JTP
