blustery
I live in southeastern Wisconsin and just moved into a home that has a well for supply of outdoor water only (ie, the well only supplies the water outside the house, inside the home is municipal water).
I've never had a well before at all and looking for some help on a few questions.
1) Over winter - I shut off the water, turned off the pump, and drained the pump. Anything else to do?
2) Under normal summer operation do I leave the water supply and pump energized or do I turn it on and off as I use it?
3) The pressure gage indicates about 50psi - the flow from the outdoor faucet itself seems ok. However, all the faucets have permanent vacuum breakers and I don't think they are closing off when I connect a hose because as much water comes out of the vacuum breaker as does the hose. So my flow from the hose is low and I'm wasting a lot of water against the foundation of the house. I have 5 outdoor faucets and they all do exactly the same thing. The hose is new, the pipes all look newer, no leaking pipes, no leaking hose - it almost seems like when I connect the hose, there is not enough pressure to close off the vacuum breaker and it thinks it needs to be venting. The vacuum breakers appear to be in decent shape and what drives me away from thinking they are at fault is that the exact same thing happens on 5 of 5 faucets. A failing or worn vacuum breaker I would buy, but all 5 doing it makes me thing it could be a pressure thing - but 50 psi also seems sufficient - any idea / suggestions? I think I have a submerged self priming pump - and with a 50 psi reading that doesn't seem like the issue either.
4) What should I expect for normal operation and sounds of the pump turning on, off, etc?
5) Again, this is outdoor water only so its not drinking water - any other maintenance to do on such on well and pump?
Anything else I should know, need to do, site where I can read up that maybe I haven't asked?
Thanks a ton for any help!
