Well and pump input
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by doug george, Sep 14, 2011.
  1. doug george
    doug george New Member
    Sep 14, 2011
    idaho
    I'm getting ready to run water to a nearly finished home. Please see updated post
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Any pump you put in that well is going to need a 2 or 3 GPM Dole valve or ball valve choking it back to keep from pumping the well dry. So you could use the pump you have now, just need to reduce its flow to less than 3 GPM. Or you could use that deep well pump in the cistern to pump water to the house and get a new 5 GPM, 1/2 HP to put in the well. The 1/2 HP AY McDonald you mentioned will not give more than 50 PSI. You need to run at 60/80 to get 70 PSI to the house, since you want 55 PSI and you have 40' rise, which equals 70 PSI. Oh, and you only need a 4.4 gallon pressure tank if you use a CSV.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
  5. doug george
    Sep 14, 2011
    idaho
    Thanks for the input......
Similar Threads: pump input
Pumps and Tanks Well Forum & Blog. Water is life. New pump design, I am not selling anything. I need your input please. Apr 13, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Using Artesian As Pump Input Apr 19, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Well pump replacement and bad advice Today at 4:05 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump issues Today at 7:09 AM
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
