TVL
I have posted here in the past and I have always received good advice. So, long story short:
I began having well issues in spring of 2013 - 4" PVC - 141 foot deep sand well - drilled in 1978 - static water level approximately 118' - used for irrigation system only
Suspected pump was going bad and had it replaced .......... the impellers were almost completely destroyed
That took care of pump issue, but replacement pump quickly pumped well dry (and yes, pump was the exact same size and specs as original)
Lowered pump from 132' to 137' with no relief. This located pump just a few inches off bottom of well
Attempts to clean 141' well by having it "blown out" were unsuccessful in restoring yield - however, the "blow out" did completely clean out the inside casing, so pump then hung about 4 feet off the VERY bottom of the casing ........... but well still could not provide the normal yield
So, I had a new well drilled just 15 feet away
New well ended up being 145' with a static water level of 117' 9", so I am assuming it is in the same aquifer as the original
Submersible pump hangs in the new well at a depth of 142' - I also had 1/4" tubing & gauge installed so I could constantly monitor water level
In the very BEGINNING, the static water level would drop approximately 13 feet while the irrigation system was functioning. This put the pump about 11 feet under water during operation and 24 feet while resting. The new well appeared to be doing its job!
The static water level drops very little now and I'm assuming it's because the well has further developed itself. The past two years as shown the static water level only drops approximately 2.5 feet during irrigation ..... and I monitor this almost daily!
So, here is what I would like to know:
1- Most importantly: the next time the pump is pulled, would it be acceptable to raise the pump so that it hangs at a new depth of approximately 135 feet. This would put the pump 10 feet off the bottom instead of just 3 feet. Current drawdown would ensure the pump is under at least 14.5 feet of water at all times. At the current depth of 142', I am not 100% sure the motor is getting proper cooling. Maybe so since this is a bottom feeding well, but it just seems to me that is a little too close to the bottom. Then again, maybe there are other valid reasons for NOT raising the pump ............ what are your thoughts?
2- The first well did so good for many years. Is it LIKELY the issue that caused the well to quit yielding properly was nothing more than sand clogging the well screen over the years?
Thanks everyone!
Thanks everyone!
